05-07-2011, 11:21 | #3992 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 464 | samsung S5600 repair imei and unlock ok her the log; Code: Model: GT-S5600 CountryCode: FTM Factory SW: S5600BVIF4 UniqueNumber: 80040000231801 MemoryPhone: K5R2G1GACC(S5600)S IMEI: 35631503221895/2 Phone S/N: RVGS875270 Build: M6281A-KLRZR-4.0.9640_1S Done with Samsung 3G tool ver 9.4 ----------------------------- Model: GT-S5600 CountryCode: FTM Factory SW: S5600BVIF4 UniqueNumber: 80040000231801 MemoryPhone: K5R2G1GACC(S5600)S IMEI: 35631503221895/2 Phone S/N: RVGS875270 Build: M6281A-KLRZR-4.0.9640_1S Reading Data from phone stage 1... OK Reading Data from phone stage 2... OK Sending PreLoader... OK Sending Loader... OK Bypass MSL... OK Reading old IMEI... OK (356315032218952) Repairing IMEI... OK New IMEI: 358801008558750 Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM109) ----------------------------- Searching USB Device... detected (COM104) Reading Phone Info... OK Model: GT-S5600 Factory SW: S5600BVIF4 CountryCode: FTM UniqueNumber: 80040000231801 MemoryPhone: K5R2G1GACC(S5600)S SW: S5603JPIE4 IMEI: 35880100855875/0 Reading SysInfo... OK Searching server... error (Maybe OLD Security) Change Mode to Qualcomm and Try Again Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM104) Reading Phone Info... OK Model: GT-S5600 Factory SW: S5600BVIF4 CountryCode: FTM UniqueNumber: 80040000231801 MemoryPhone: K5R2G1GACC(S5600)S SW: S5603JPIE4 IMEI: 35880100855875/0 Reading SysInfo... OK Searching server... OK Calculating codes... OK (time - 00:00:31) Freeze code: 15385359 NET lock: #7465625*638*42850752# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*12369874# SIM lock: #7465625*746*12369874# For check lock status: *#7465625# |
05-07-2011, 11:29 | #3993 (permalink) |
No Life Poster Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | LG 2-3G Tool v.2.1.8 supported models: 386 Not detect phone! Please manual select port or reboot PC! Not detect phone! Please manual select port or reboot PC! Not detect phone! Please manual select port or reboot PC! Selected model: C1200 Selected port: COM4 Selected speed: 921600 Please press and hold power button! Phone detected! Loader not startup! Selected model: C1200 Selected port: COM4 Selected speed: 921600 Please press and hold power button! Phone detected! Loader startup Ok.. Reading phone info... Flash ID: 980084 Flash type: TH50VPF5783AASB Flash size: 16Mb IMEI: 353583-00-037174-8 Start unlock... Read call. data... Patch call. data Write call. data... Unlock succesfully! Elapsed: 0 secs. --> (v.2.1.8) Start read FullFlash... Start read CodeData... Stop by user! Elapsed: 19 secs. --> (v.2.1.8) |
05-07-2011, 13:25 | #3994 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | M310 Samsung M310 succesfully unlocked. Thank you Z3X Team. BR. Selected model: M310 Selected com port: COM4 Selected speed port: 921600 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: M310BGHF1 IMEI: 3571320263xxxx MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 16 second, sw ver: 3.5.0012 |
05-07-2011, 13:29 | #3995 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Selected model: C3630 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Phone in TAT MODE Phone IMEI: 35514104077387 Phone SW: C3630XXJJ6 Phone BT ADDR: 60A1-0A-F48603 Phone SN: RUNZB58269 [FREZEE]:11562070 [NET LOCK]:40773874 [Subset LOCK]:00000000 [SP LOCK]:40773874 [CP LOCK]:00000000 [Sim LOCK]:12369874 [Activa LOCK]:12369874 Read info - ok Elapsed time: 17 second, sw ver: 3.5.0015 ------------------------------------------------------------------------------- |
05-07-2011, 13:45 | #3996 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | s3100 unlock done Selected model: M620 Selected com port: COM3 Selected speed port: 921600 Decode *.s3 file - please wait segments 9 segment 1 20078000 1096704 byte segment 2 2000C000 20684 byte segment 3 20058000 56 byte segment 4 20058138 17710 byte segment 5 2003803C 36684 byte segment 6 20000000 100 byte segment 7 20300000 29069860 byte segment 8 2001E000 160 byte segment 9 20016000 5056 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 0100003D7E22 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 9 Format FFS - wait... OK Send content - wait... OK Elapsed time: 1074 second, sw ver: 3.5.0015 ------------------------------------------------------------------------------- |
05-07-2011, 13:46 | #3997 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | E1150 unlock done Selected model: E1150 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# |
05-07-2011, 13:52 | #3998 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Selected model: C3053 Selected com port: COM3 Selected speed port: 460800 Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 24683020 byte segment 3 2001E000 180 byte segment 4 20016000 26012 byte segment 5 20078000 1132556 byte segment 6 2000C000 21404 byte segment 7 20058000 56 byte segment 8 20058138 16924 byte segment 9 2003803C 36508 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 890000007E88 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 124 Format FFS - wait... OK Send content - wait... OK |
05-07-2011, 14:07 | #3999 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Selected model: E2210 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35856703347204 Phone SW: E2210BAGIF3 Phone BT ADDR: E8E5-D6-79EF1F Phone SN: RPOZ625838 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok |
05-07-2011, 14:09 | #4000 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Selected model: U600 Selected com port: COM3 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: 00BBVHD1 Langpack: Orange, Switzerland IMEI: 35166503365090 S/N: RU2S149656 HW-> MP 0.501 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 0023d7-a20ddb Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*32174234# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok |
05-07-2011, 14:11 | #4001 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Selected model: E1170 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Phone IMEI -> 35504904654506 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]:00671800,00671800,00671800, [SIM LOCK]:00000000,00000000,00000000, [PHONE LOCK]:00000000,00000000,00000000, [SP LOCK]:00000000,00000000,00000000, Read Info - ok Selected model: E1170 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 06 Sending loader2... OK Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# |
05-07-2011, 14:13 | #4002 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Selected model: E1081T Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# |
05-07-2011, 14:17 | #4004 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Selected model: S5620 Selected com port: COM126 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM126 Phone OLD IMEI: 35343504719398 /3 Phone SW: S5620BVIJB2_JC4/S5620ZVVJB2_JC4 Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM10 Send loader... OK Wait for boot ... Phone must be ON Search modem ... OK Search modem on:COM126 MSL DEACTIVATED - TRUE Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Search flash modem ... Search flash modem ... Search flash modem ... Search flash modem ... OK Search flash modem on:COM10 Send loader... OK |
05-07-2011, 14:19 | #4005 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | sw ver: 3.5.0014Selected model: G600 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3541 Sending loader2... OK Flash ID: 00EC2206000100000034 Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok TFS flash - ok Download - ok |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
