02-19-2010, 18:59 | #526 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | Quote:
02-19-2010, 22:56 | #527 (permalink) |
No Life Poster Join Date: Jul 2005 Location: turkey, izmir
Member: 163458 Status: Offline Sonork: 100.1606694 Thanks Meter: 503 | kp215 imei repair ok Please press and hold power button! Phone detected! Loader startup Ok.. Reading phone info... Flash ID: 20880E Flash type: M30L0T800B0 Flash size: 32Mb IMEI: 3581********** Read call. data... Patch call. data Write call. data... Repair succesfully! Elapsed: 11 secs. |
02-20-2010, 08:23 | #528 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Somewhere there Age: 14
Member: 567723 Status: Offline Thanks Meter: 314 | S8000 Unlock Success Code: Preved! Count supported models - 146 Server news: [14.02.2010] Samsung Smart Phone Tool Update 2.3.45 [12.02.2010] Samsung Tool 3.4.0030 - E1130B,E1150,C3510,B3410 and more. [01.02.2010] LG Qualcomm 1.7.9 released! Direct unlock and Imei repair for GU280, GU280f, GU285, GU285f, GU285g first in the world! :) Added BL40e, BL40f, BL40g. ----------------------------------- READ NEWS FOR DETAILS! Reading file as S8000... ok Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Searching Samsung USB Flash interface... detected (COM8) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:24) Searching Samsung USB interface... detected (COM8) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 357041032151097 Unlock as MSL3... OK (time - 00:00:01) >>> GsmFreeShop <<< |
The Following User Says Thank You to GsmFreeShop For This Useful Post: |
02-20-2010, 09:20 | #529 (permalink) |
No Life Poster Join Date: Mar 2008 Location: China/USA
Member: 718425 Status: Offline Thanks Meter: 5,873 | Selected model: M3510 Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 35872302224127 Phone SW: M3510DXIB1 Phone BT ADDR: 0026-5F-B97A0F Phone SN: RUXS861713 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 15 second, sw ver: 3.4.0030 |
The Following 2 Users Say Thank You to R@ZIB-BD For This Useful Post: |
02-20-2010, 10:46 | #530 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | samsung c130 remove password 100/100 ok samsung c130 remove password 100/100 ok with z3xbox Code: READ NEWS FOR DETAILS! Last version on support: 2G tools v3.4.0030 Selected model: C130 Selected com port: COM146 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: C130XXFG1 IMEI: 35405501766572 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok Elapsed time: 8 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Card removed!:) |
02-20-2010, 10:54 | #531 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | S5600 Unlocked. Searching Qualcomm USB interface... detected (COM27) Model: S5600 IMEI: 35264103****** SW: S5600BGIF3 Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 00:00:37) Freeze code... 16190583 NET lock code... 70493741 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 How to enter codes: NET: #7465625*638*70493741# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*12369874# For check lock status: *#7465625# |
The Following User Says Thank You to fasttechjlm For This Useful Post: |
02-20-2010, 13:01 | #532 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | u600 unlock done Phone must be ON! Please, connect phone Entering TestMode... OK SW: U600CPGG2 Langpack: Finland IMEI: 35880301564135 S/N: R6YPA02105 HW-> MP 2.101 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 001df6-2c3be4 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*63385134# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 9 second, sw ver: 3.4.0030 |
The Following User Says Thank You to themobileshop For This Useful Post: |
02-21-2010, 09:13 | #534 (permalink) |
No Life Poster Join Date: Feb 2007 Location: philippines
Member: 448980 Status: Offline Thanks Meter: 136 | here's ks360 unlocked by read codes... PMB8888 Module 1.1 started. SW: Ver 2.2.2.162 Please connect phone , it must be powered off BOOT Failed Disconnected. PMB8888 Module 1.1 started. SW: Ver 2.2.2.162 Connecting to KS360 in UART Mode (COM35 ,115200) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8888) prebooting... Release power button. Booting... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:355429024142236 Unlock codes: NCK[0]: 13656136 (LOCKED) Reading codes... Sending SEC pack... Reading ... Analising EEPROM... Phone IMEI:355429024142236 For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): NCK[0]: 13656136 (LOCKED) i choose read codes instead of direct unlock for safe purposes. |
The Following User Says Thank You to ps_tech For This Useful Post: |
02-21-2010, 12:21 | #535 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | M7600 unlock successful.... Type *#782872# to get phone into Qualcomm mode Connect cable and install qualcomm drivers! open Z3x software select correct model! Check on Qualcomm mode for Unlock Nvm Select "Read Codes(NEW)" Press SP unlock and wait untill software read codes from phone...... Here is log of that phone which i successfully unlocked! Code: Searching Qualcomm USB interface... detected (COM83) Model: M7600 IMEI: 35282603049933 SW: M7600BVID5 Reading data from phone... OK Reading security... error! (Insert SIM or type *#7465625#) Searching Qualcomm USB interface... detected (COM83) Model: M7600 IMEI: 3528260304xxxx SW: M7600BVID5 Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 00:00:42) Freeze code... 48164847 NET lock code... 64161539 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 How to enter codes: NET: #7465625*638*64161539# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*12369874# For check lock status: *#7465625# |
The Following User Says Thank You to MUNEEB_AKHTAR_RAZA For This Useful Post: |
02-22-2010, 09:20 | #536 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Unlock E2120 In FLash Mode Last version on support: 2G tools v3.4.0030 Selected model: E2120 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35492703524748 Phone SW: E2120AYIK1 Phone BT ADDR: 0000-00-000000 Phone SN: RVSSC82841 Deactivated MSL - FAIL Use alternative method Unlock - ok Elapsed time: 34 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Selected model: E2120 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 48 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Br UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
02-22-2010, 21:17 | #537 (permalink) |
Junior Member Join Date: Feb 2007
Member: 447114 Status: Offline Thanks Meter: 0 | Samsung Avila GPS S5230G --------------------------- 2010-02-22 18:47:48 ----------------------------- Selected model: S5230 Selected com port: COM5 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM12 Model: GT-S5230G CountryCode: PLS Factory SW: S523GCXJA3 UniqueNumber: 55170000678460 MemoryPhone: K522H1HACC(S5230G) Phone IMEI: 3597450xxxxxxxx /1 Phone S/N: RQEZ128703 Phone Bluetooth ID: A8 F2 74 26 41 35 Phone SW: S523GBKJA1 Phone HW: MP 0.300 Phone CalData ver: 20100126 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:26151602 [NET LOCK]:86093180 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 88 sec Elapsed time: 140 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- |
02-23-2010, 09:32 | #538 (permalink) |
Member: 977491 Status: Offline Thanks Meter: 82 | B270i unlock done. Selected model: B270I Selected com port: COM77 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 33 second, sw ver: 3.4.0030 |
02-23-2010, 12:00 | #539 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | samsung GT-E2120 FLASH OK WITH Z3XBOX [IMG]file:///C:/DOCUME%7E1/BRYAN/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]--------------------------- 23/02/2010 11:43:19 ----------------------------- Server news: [01.02.2010] LG Qualcomm 1.8.1 released! Direct unlock and Imei repair for BL20t, BL42k. [20.02.2010] China Editor 4.0 released! New GUI, phone menu preview, new firmware types, local DB and many more! [16.02.2010] Samsung Smart Phone Tool Update 2.3.50 [12.02.2010] Samsung Tool 3.4.0030 - E1130B,E1150,C3510,B3410 and more. ----------------------------------- READ NEWS FOR DETAILS! Last version on support: 2G tools v3.4.0030 Selected model: E2120 Selected com port: COM146 Selected speed port: 230400 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Download - ok Elapsed time: 1305 second, sw ver: 3.4.0030 --------------------------------------------------------- |
02-23-2010, 18:15 | #540 (permalink) |
Freak Poster Join Date: Aug 2008 Location: sweden
Member: 844520 Status: Offline Thanks Meter: 26 | hi there unlock Samsung E2210B done ok , Last version on support: 2G tools v3.4.0030 Selected model: E2210 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35--------------- Phone SW: E2210BXBIJ2 Phone BT ADDR: 5492-BE-A15753 Phone SN: RPUZ131374 Deactivated MSL - TRUE [FREZEE]: 67510500 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 15 second, sw ver: 3.4.0030 ------------------------------------------------------------------ |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
