04-03-2012, 12:51 | #6676 (permalink) |
Freak Poster Join Date: Mar 2011 Location: m + koti hyd 95
Member: 1532828 Status: Offline Thanks Meter: 77 | c3222 unlocked Selected com port: COM188 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222DDKH2 Phone CSC: C3222ODDKD1 Phone BT ADDR: E4B0-21-0F30C7 Phone IMEI: 35726204664039 Deactivated MSL - TRUE [FREZEE]: 31350550 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00015858 [Phone Lock]: 98765432 Read info - ok Elapsed time: 133 second, sw ver: 3.5.0035 |
04-03-2012, 17:10 | #6677 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Paraguay
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock S5600L Done! Tick New Algo (Use Server/Loader) Code: Searching Samsung USB Modem... Detected (COM22) Model: GT-S5600L SW: S5600LVDIE1 IMEI: 35950403 Model: GT-S5600L Country Code: PSN Factory SW: VDIE1_IL1 Unique Number: 80900000614122 Memory Phone: K5R2G1GACC(S5600)S Checking Phone On COM23... OK Reading Phone Info... OK Model: GT-S5600L Country Code: PSN Cal Date: 2009-12-29 Factory SW: VDIE1_IL1 Unique Number: 80900000614122 Memory Phone: K5R2G1GACC(S5600)S Phone S/N: RU9Z249214 Build: SBAM6281A-KLRZR-4.0.9640_4G IMEI: 35950403 Done with Samsung Tool ver 12.2 Searching Samsung USB Modem... Detected (COM22) Reading Phone Info... OK Model: GT-S5600L SW: S5600LVDIE1 IMEI: 35950403 Country Code: PSN Factory SW: VDIE1_IL1 Unique Number: 80900000614122 Memory Phone: K5R2G1GACC(S5600)S Reading SysInfo... OK Searching server... OK Unlocking ... OK Done with Samsung Tool ver 12.2 |
04-03-2012, 23:34 | #6678 (permalink) |
Junior Member Join Date: Feb 2012 Location: sterling hts michigan
Member: 1723500 Status: Offline Thanks Meter: 1 | this is the SGH-A137 reads unlock codes , for some reason this phone has to locks when info is read by Z3X software and there is 2 ways to unlock this device is by NSpro box and Z3x box , anyways , i read the codes than phone powers up , i input EEP reset codes this 1) *2767*3855# than phone resets EEP 2) #7465625*638*--------# shoul say NETWORK Deactivated , now here is the tricky part . when inputting this code make sure u dont press * instead of # when you press the * button you basically locking network back instead of unlock , 3) when done input network codes , take out battery than put back in , power device and wait to update network automatically , by the way lots of people think that the device its not unlocked is because they have no patients at all . please pay attention to the thread before complaining about how to do this , this is the easiest it gets . this goes to noobies ok not the pro and joes |
04-05-2012, 13:13 | #6679 (permalink) |
No Life Poster Join Date: Oct 2011 Location: gsmsection
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | Reading Phone Info... OK Model: GT-S5830 Country Code: OPENÇâ Cal Date: 2011-01-20 Factory SW: S5830JPKA7_OJPKA7 Unique Number: 55630000956130 Memory Phone: KAT007012B(S5830) Phone S/N: RQ6B301838 Build: M76XX-TSNCJOLYM-6050 IMEI: 357238041508172 PDA/CSC Version: S5830JPKA7/S5830OJPKA7 Phone version: S5830JXKA3 Phone HW: MP 0.600 Cal Date: 2011.03.26 Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.2 |
04-06-2012, 11:44 | #6680 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | B3410 2505DB02 error solved Code: Selected model: B3410 Selected com port: COM10 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok TFS flash - ok Start Flash CSC CSC format - ok Mount CSC - ok Create DIR - ok CSC flash - ok Write signature - ok Download - ok Elapsed time: 1384 second, sw ver: 3.5.0035 |
04-06-2012, 13:04 | #6681 (permalink) |
Freak Poster Join Date: Nov 2009 Location: U.K (leeds)
Member: 1157490 Status: Offline Sonork: 100.1638346 Thanks Meter: 74 | Galaxy y S5363 unlocked successfully. While unlocking if gives you root error,you need to root the phone with micro sd card.(Universal_GB_ROOT_V9.zip).Use this software on your sd card and update zip on the the phone.After update zip just press ulock on Z3X.You are done tested 100%. Count supported models - 302 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5363 Phone Version: S5363XXKK3 PDA Version: S5363XXKK3 CSC Version: S5363O2UKK1 IMEI: 358841041154498 Rooting Phones... Error Done with Samsung Tool ver 12.2 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5363 Phone Version: S5363XXKK3 PDA Version: S5363XXKK3 CSC Version: S5363O2UKK1 IMEI: 358841041154498 Rooting Phones... Error Done with Samsung Tool ver 12.2 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5363 Phone Version: S5363XXKK3 PDA Version: S5363XXKK3 CSC Version: S5363O2UKK1 IMEI: 358841041154498 Rooting Phones... Error Done with Samsung Tool ver 12.2 Starting ADB Server... OK Checking ROOT... TRUE Reading Phone Info... OK Android Version: 2.3.6 Model: GT-S5363 Phone Version: S5363XXKK3 PDA Version: S5363XXKK3 CSC Version: S5363O2UKK1 IMEI: 358841041154498 Reading Data From Phone... OK Unlocking... OK Done with Samsung Tool ver 12.2 Regards, Champions. |
04-06-2012, 13:12 | #6682 (permalink) |
Member: 1532828 Status: Offline Thanks Meter: 77 | samsung A687 unlocking done 2 pice Count supported models - 223 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&186aabf4&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:26) Freeze code: 61815972 NET lock: #7465625*638*62402939# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&186aabf4&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:33) Freeze code: 81715949 NET lock: #7465625*638*83093796# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
04-06-2012, 16:13 | #6683 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Hungary Age: 53
Member: 9862 Status: Offline Thanks Meter: 23 | Samsung S5260 is done with sw ver: 3.5.0035 Selected model: S5260 Selected com port: COM10 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM9 Model: GT-S5260 CountryCode: PAN Factory SW: S5260XXKG2_OXDKH1 UniqueNumber: 77071000403917 MemoryPhone: K5W2G1HACI(S5260) Phone IMEI: 3591150437xxxx /x Phone S/N: RQ9BB60718 Phone Bluetooth ID: FC C7 34 87 59 22 Phone SW: S5260XXKG2 Phone HW: MP 0.400 Phone CalData ver: 20111115 Searching server... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:07519729 [NET LOCK]:41952517 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 49 sec Elapsed time: 61 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- |
04-06-2012, 17:18 | #6684 (permalink) |
Temporary banned !! Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | S8500 Flashed successfully Count supported models - 302 Checking Phone On COM3... OK Reading Phone Info... OK Model: GT-S8500 Country Code: ONE Cal Date: 2010-07-28 Factory SW: S8500BVJF1_ONEJF1 Unique Number: 86050000315676 Memory Phone: KAC007021M(S8500) Phone S/N: RUOZ894066 Build: Q6270B-KPUBL-1.5.45072S IMEI: 351781049944572 Done with Samsung Tool ver 12.2 Checking Phone On COM3... OK Reading Phone Info... OK Model: GT-S8500 Country Code: ONE Cal Date: 2010-07-28 Factory SW: S8500BVJF1_ONEJF1 Unique Number: 86050000315676 Memory Phone: KAC007021M(S8500) Phone S/N: RUOZ894066 Build: Q6270B-KPUBL-1.5.45072S IMEI: 351781049944572 Done with Samsung Tool ver 12.2 Done with Samsung Tool ver 12.2 Searching Samsung USB Flash Interface... detected (COM14) Sending BOOT_LOADER.mbn... OK Sending Dbl.mbn... OK Flashing BOOT Files Done (time - 00:00:01) Wait, Reset... OK Sending AMSS... OK Sending APPS... OK Sending RSRC1... OK Sending RSRC2... OK Sending FFS... OK Sending CSC... OK Sending SHP APP... OK Flashing Done (time - 00:16:50) Done with Samsung Tool ver 12.2 |
04-06-2012, 17:34 | #6685 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 249801 Status: Offline Thanks Meter: 12 | Selected model: C3222 Selected com port: COM188 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222DDKH2 Phone CSC: C3222ODDKD1 Phone BT ADDR: E4B0-21-0F30C7 Phone IMEI: 3572******** Deactivated MSL - TRUE [FREZEE]: 00000000 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 0000000 [Phone Lock]: 12345678 Read info - ok |
04-06-2012, 19:17 | #6686 (permalink) |
Freak Poster Join Date: Feb 2011 Location: in the darkness
Member: 1516808 Status: Offline Thanks Meter: 95 | A516 Unlocked Selected model: A516 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Timeout Phone fail TAT MODE Deactivated MSL - FAIL Use alternative method Unlock - FAIL Selected model: A516 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3541 Sending loader2... OK Flash ID: 00EC2206000100000014 Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 165 second, sw ver: 3.5.0034 |
04-07-2012, 09:07 | #6687 (permalink) |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Unlocked Galaxy S2 with Z3x Unlocked Galaxy S2 with Z3x Thanks Z3x tteam |
The Following 3 Users Say Thank You to unlock phones For This Useful Post: |
04-07-2012, 17:20 | #6689 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Amman, J o r d a n. Age: 43
Member: 1529244 Status: Offline Sonork: 1720 Thanks Meter: 150 | Done with Samsung Tool ver 12.0 Searching Samsung USB Modem... Detected (COM75) Model: SGH-T669 SW: T669UVJK2 IMEI: 353652046220449 Model: SGH-T669 Country Code: TMB Factory SW: UVJK2 Unique Number: 55210001020710 Memory Phone: K5W2G1HACF(T669)S Checking Phone On COM120... OK Reading Phone Info... OK Model: SGH-T669 Country Code: TMB Cal Date: 2010-11-22 Factory SW: UVJK2 Unique Number: 55210001020710 Memory Phone: K5W2G1HACF(T669)S Phone S/N: RPYZC43183 Build: Q6270B-KPVZL-1.5.40034ST IMEI: 353652046220449 Done with Samsung Tool ver 12.0 Reading Phone Info... OK Model: SGH-T669 Country Code: TMB Cal Date: 2010-11-22 Factory SW: UVJK2 Unique Number: 55210001020710 Memory Phone: K5W2G1HACF(T669)S Phone S/N: RPYZC43183 Build: Q6270B-KPVZL-1.5.40034ST IMEI: 353652046220449 Reading SysInfo... OK Searching server... OK Unlocking ... OK Done with Samsung Tool ver 12.0 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
