08-09-2009, 13:05 | #91 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: philippines
Member: 245748 Status: Offline Thanks Meter: 91 | success unlock S5233s with simple procedure unlock thru e210 combo cable ( rj45 and usb) UNLOCKING NETWORK LOCK and RESET PHONE LOCK(00000000) * with e210 rj45 connect cable to box port to phone without battery *select model S5230 * click direct unlock button *attach battery to the phone (phone will automatically power on and software detect phone/device *wait a few second until phone restart then disconnect rj45 and after that connect data cable (usb e210) be sure drivers installed properly >>>> Quote:
whehehehehehehe | |
The Following 2 Users Say Thank You to markali2006 For This Useful Post: |
08-20-2009, 12:56 | #96 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | :::::::::::::s8300:::::::::::: Searching Qualcomm USB interface... detected (COM24) Model: S8300 SW: S8300XFIC4 Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM24) Model: S8300 SW: S8300XFIC4 Unlock as MSL2 Direct... ok |
The Following User Says Thank You to karikari For This Useful Post: |
08-22-2009, 11:40 | #97 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 44
Member: 129486 Status: Offline Thanks Meter: 66 | A707 Hello i have unlock A707 today unfreeze without flashing see log. OLD VER NOT UNLOCK UNFREEZE Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM139) Model: A707 IMEI: 355458012XXXXX SW: A707UCGL4 Unlock as MSL2 Direct... ok NEW VER UNLOCK DONE UNFREEZE Searching Samsung USB interface... not found Searching Qualcomm USB interface... detected (COM139) Model: A707 SW: A707UCGL4 Unlock as MSL2 Direct... ok |
08-30-2009, 06:13 | #100 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | READ NEWS FOR DETAILS! Searching Qualcomm USB interface... detected (COM164) Model: S5600 SW: S5600BVIDA Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 0:01:35) Freeze status... ON NET lock status... ON Freeze code...59641852 NET lock code...15368083 SP lock code...00000000 CP lock code...00000000 |
08-31-2009, 08:34 | #101 (permalink) |
Freak Poster Join Date: Jul 2008 Location: china
Member: 817951 Status: Offline Sonork: 100.1584874 Thanks Meter: 52 | U708 UNLOCK OK Normal mode required Searching Samsung USB interface... detected (COM26) Checking mobile state... flash Normal mode required Searching Samsung USB interface... detected (COM26) Checking mobile state... normal Model: SGH-U708 SW: U708ZHGF3 IMEI: 353883022191581 Searching Samsung USB interface... detected (COM26) Checking mobile state... normal Model: SGH-U708 SW: U708ZHGF3 IMEI: 353883022191581 Unlock as MSL2 Direct... ok (NSK - 12345678)! B.R KIKEN |
08-31-2009, 11:02 | #102 (permalink) |
No Life Poster Join Date: Oct 2008 Location: HPS
Member: 878925 Status: Offline Sonork: ;-) Thanks Meter: 786 | SAMSUNG E1310B Code: ---------------------------------------------------------------------------- Connect phone and press power 3 seconds Phone Detected Loader1 - ok Unlock block Unlock block Unlock - ok If lock - not deactivate: try with code 00000000 Elapsed time: 63 second ---> with soft version -> 3.3 beta 0008 ---------------------------------------------------------------------------- |
The Following User Says Thank You to digiphone For This Useful Post: |
09-04-2009, 10:08 | #104 (permalink) |
Member: 878925 Status: Offline Sonork: ;-) Thanks Meter: 786 | Samsung d880 Code: ---------------------------------------------------------------------------- Connect phone and power on Phone Detected Send loader1 Loader1 - ok ARM version 4541 Loader2 - ok Unlock block Unlock block Unlock block Unlock block Unlock - ok If lock - not deactivate: try with code 00000000 Elapsed time: 113 second ---> with soft version -> 3.3 beta 0008 ---------------------------------------------------------------------------- |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
