11-16-2015, 06:10 | #14852 (permalink) |
Freak Poster Join Date: Apr 2011 Location: BANGLADESH Age: 29
Member: 1553137 Status: Offline Sonork: 100.1652229 Thanks Meter: 56 | Sm-j700f unlock done Code: Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 5.1.1 Product code: SM-J700FZDDXME Phone version: J700FXXU1AOI3 PDA version: J700FXXU1AOI5 CSC version: J700FOLB1AOI1 CSC country code: MALAYSIA CSC sales code: XME HW version: MP 0.701 Phone S/N: R28GA3CMHTL Modem board: SHANNON310 RF cal date: 20151030 IMEI: Checking Super user right... true Reading nv data... OK OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.3 |
11-16-2015, 08:36 | #14853 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | SM-G530H DIRECT UNLOCK DONE! Code: UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G530H Selected port: COM47 SAMSUNG Mobile USB Serial Port Software version: 23.3 Reading phone info... Reading IMEI... OK IMEI: Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.23.3 |
11-16-2015, 09:00 | #14854 (permalink) | |
Freak Poster Join Date: Sep 2010 Location: Uzbekistan/Namangan/Sardoba
Member: 1396837 Status: Offline Sonork: 100.1657369 Thanks Meter: 17 | G531H samsung accaunt remove 1 sec. thanks. Quote:
11-16-2015, 09:14 | #14855 (permalink) |
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | SM-G313HU HANG ON LOGO SOLVED BY FLASHING WITH Z3X PRO 23.3 Code: Operation: Flash Selected model: SM-G313HU Software version: 23.3 File analysis... OK Total file size: 0x3B0A4294 (944 Mb) Searching USB Flash Interface... detected COM45 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending system.img... OK Sending hidden.img... OK Sending BcmBoot.img... OK Sending param.lfs... OK Flashing done (time - 00:06:56) Done with Samsung Tool PRO v.23.3 |
11-16-2015, 14:40 | #14860 (permalink) |
Insane Poster Join Date: Sep 2007 Location: pakistan Age: 36
Member: 584797 Status: Offline Sonork: 100.1669180 Thanks Meter: 15 | GT-I9100 repair IMEI don With Z#X 23.3 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' if needed. Operation: Repair Selected model: GT-I9100 Software version: 23.3 Waiting ADB device... OK Reading phone info... Model: GT-I9100 Android version: 4.1.2 Product code: Not Active Phone version: I9100XXMS2 PDA version: I9100ZSMSA CSC version: I9100OZSMSA CSC country code: Hong Kong CSC sales code: TGY HW version: REV__ Phone S/N: 00000000000 Modem board: RF cal date: none IMEI: 004999010640000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.23.3 thanks Z3X-teem |
11-16-2015, 17:01 | #14861 (permalink) |
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | GT-I9100 HANG ON LOGO SOLVED BY FLASH WITH Z3X Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-I9100 Software version: 23.3 File analysis... OK Total file size: 0x28A0E1C0 (650 Mb) Searching USB Flash Interface... detected COM19 Setup connection... OK Reading PIT from phone... OK Sending boot.bin... OK Sending Sbl.bin... OK Sending param.lfs... OK Sending zImage... OK Sending factoryfs.img... OK Sending data.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:05:00) Done with Samsung Tool PRO v.23.3 |
11-17-2015, 07:08 | #14862 (permalink) |
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | SM-G361H NETWORK LOCK CODE READ DONE! Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G361H Software version: 23.3 Searching Samsung modem... detected COM58 Reading phone info... OK Model: SM-G361H Version: G361HXXU0AOG3/G361HOJV0AOG1/G361HXXU0AOF8/G361HXXU0AOG3 Product code: SM-G361HZSDKSA Phone S/N: R51G71YY3KR Imei: Unique number: CQN0072C1FEAF72 Reading codes... OK Please wait, calculating codes... OK (time - 00:09:31) Freeze code: 63936169 NET lock: 97197190 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.3 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
