10-06-2020, 09:16 | #1591 (permalink) |
No Life Poster Join Date: Jan 2020 Location: Algeria
Member: 2944109 Status: Offline Thanks Meter: 656 | Samsung Grand Prime + (SM-G532F) FRP Reset Code: Operation: Reset FRP Selected model: SM-G532F Software version: 41.2 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 PDA version: G532FXWU1ASB1 CSC version: G532FOJV1ASB1 Phone version: G532FXXU1ARF3 Product code: SM-G532FZSDTKD CSC country code: Algeria CSC sales code: TKD Phone SN: R28XXXXK1P IMEI: 352XXXXXXXXXX65 HW version: MP 0.300 RF cal date: 20181115 Chip name: MT6737T Modem board: MT6737T Security patch: 2018-08-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.41.2 |
10-10-2020, 16:05 | #1592 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J120AZ Software version: 41.2 Checking hash file... OK Searching Samsung modem... detected COM156 Reading phone info... Model: NONE AP version: J120AZTUS5ARA1 CSC version: NONE CP version: J120AUCU5ARA1 Phone SN: R58H53X8H0Y IMEI: 356419073590772 Unique number: CFN00FE85D22243 Incorrect model selected. This may damage your phone. Continue? Yes Searching Samsung diag port... detected COM157 Reading phone info... OK CP version: J120AUCU5ARA1 CP build: Jan 10 2018 16:21:16 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON308 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:00) Freeze code: 14258613 NET lock: 06809283 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.2 good link here https://mega.nz/file/gLJBxIIC#qrdRB7...FE6PnPHeOLkpX0 |
10-13-2020, 16:25 | #1593 (permalink) |
Freak Poster Join Date: Nov 2006 Location: pkistan
Member: 395389 Status: Offline Sonork: no idi Thanks Meter: 193 | A105fn imei repair successfully Repair ] Operation: Repair [ Repair ] Selected model: SM-A105FN [ Repair ] Software version: 41.2 [ Repair ] [ Repair ] Waiting ADB device... OK [ Repair ] Reading phone info... [ Repair ] Model: SM-A105FN [ Repair ] Android version: 9 [ Repair ] PDA version: A105FNXXU2ASG1 [ Repair ] CSC version: A105FNOXM2ASG1 [ Repair ] Phone version: A105FNXXU2ASG1 [ Repair ] Product code: SM-A105FZBUXEU [ Repair ] CSC country code: UK & IRE [ Repair ] CSC sales code: XEU [ Repair ] Phone SN: R58M78R8B5E [ Repair ] IMEI: 356 [ Repair ] HW version: MP 0.100 [ Repair ] RF cal date: 20190730 [ Repair ] Chip name: EXYNOS7884B [ Repair ] Modem board: SHANNON327 [ Repair ] Security patch: 2019-07-01 [ Repair ] Boot Warranty bit: 1 [ Repair ] SIM State: ABSENT,ABSENT [ Repair ] Initialization zTool... OK [ Repair ] Running zTool, please wait... OK [ Repair ] Reading data from phone... OK [ Repair ] Searching server... OK [ Repair ] Checking server answer... OK [ Repair ] Executing... OK [ Repair ] Reading data from phone... OK [ Repair ] Calculating... OK [ Repair ] Searching server... OK [ Repair ] Waiting for server answer... OK [ Repair ] Writing security... OK [ Repair ] Rebooting phone... OK [ Repair ] |
10-13-2020, 16:26 | #1594 (permalink) |
Member: 395389 Status: Offline Sonork: no idi Thanks Meter: 193 | [ Patch Certificate ] Operation: Patch Certificate [ Patch Certificate ] Selected model: SM-A105FN [ Patch Certificate ] Software version: 41.2 [ Patch Certificate ] [ Patch Certificate ] Waiting ADB device... OK [ Patch Certificate ] Reading phone info... [ Patch Certificate ] Model: SM-A105FN [ Patch Certificate ] Android version: 9 [ Patch Certificate ] PDA version: A105FNXXU2ASG1 [ Patch Certificate ] CSC version: A105FNOXM2ASG1 [ Patch Certificate ] Phone version: A105FNXXU2ASG1 [ Patch Certificate ] Product code: SM-A105FZBUXEU [ Patch Certificate ] CSC country code: UK & IRE [ Patch Certificate ] CSC sales code: XEU [ Patch Certificate ] Phone SN: R58M78R8B5E [ Patch Certificate ] IMEI: 358 [ Patch Certificate ] HW version: MP 0.100 [ Patch Certificate ] RF cal date: 20190730 [ Patch Certificate ] Chip name: EXYNOS7884B [ Patch Certificate ] Modem board: SHANNON327 [ Patch Certificate ] Security patch: 2019-07-01 [ Patch Certificate ] Boot Warranty bit: 1 [ Patch Certificate ] SIM State: ABSENT,ABSENT [ Patch Certificate ] Checking Super user right... true [ Patch Certificate ] Initialization zTool... OK [ Patch Certificate ] Running zTool, please wait... OK [ Patch Certificate ] Reading data from phone... OK [ Patch Certificate ] Searching server... OK [ Patch Certificate ] Checking server answer... OK [ Patch Certificate ] Executing... OK [ Patch Certificate ] Searching server... OK [ Patch Certificate ] Waiting for server answer... OK [ Patch Certificate ] Patching... OK [ Patch Certificate ] Rebooting phone... OK |
10-14-2020, 10:33 | #1595 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | repair imei done m107f Code: Waiting ADB device... OK Reading phone info... Model: SM-M107F Android version: 9 PDA version: M107FXXS2ATB1 CSC version: M107FODM2ATB2 Phone version: M107FDDS2ATB1 Product code: SM-M107FMBDINS CSC country code: India CSC sales code: INS Phone SN: RZ8MC07FY0T IMEI: 352545698745666 HW version: REV0.3 RF cal date: 20191203 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2020-02-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.41.2 |
10-15-2020, 11:08 | #1596 (permalink) |
Freak Poster Join Date: Oct 2016 Location: SUDAN
Member: 2637339 Status: Offline Thanks Meter: 44 | SM-A115F Downgrade DONE 9-2020______7-2020 File analysis... OK [ Flash ] Total file size: 0x11AB39C46 (4523 Mb) [ Flash ] Searching USB Flash interface... COM68 detected [ Flash ] Setup connection... OK [ Flash ] Set PIT file... OK [ Flash ] Reading PIT from phone... OK [ Flash ] Sending aboot.mbn.lz4... OK [ Flash ] Sending sbl1.mbn.lz4... OK [ Flash ] Sending rpm.mbn.lz4... OK [ Flash ] Sending tz.mbn.lz4... OK [ Flash ] Sending devcfg.mbn.lz4... OK [ Flash ] Sending cmnlib_30.mbn.lz4... OK [ Flash ] Sending cmnlib64_30.mbn.lz4... OK [ Flash ] Sending km4.mbn.lz4... OK [ Flash ] Sending apdp.mbn.lz4... OK [ Flash ] Sending msadp.mbn.lz4... OK [ Flash ] Sending NON-HLOS.bin.lz4... OK [ Flash ] Sending sec.dat.lz4... OK [ Flash ] Sending adspso.bin.lz4... OK [ Flash ] Sending bksecapp.mbn.lz4... OK [ Flash ] Sending vaultkeeper.mbn.lz4... OK [ Flash ] Sending boot.img.lz4... OK [ Flash ] Sending dtbo.img.lz4... OK [ Flash ] Sending recovery.img.lz4... OK [ Flash ] Sending super.img.lz4... OK [ Flash ] Sending userdata.img.lz4... OK [ Flash ] Sending vbmeta.img.lz4... OK [ Flash ] Sending metadata.img.lz4... OK [ Flash ] Sending modem.bin... OK [ Flash ] Sending cache.img.lz4... OK [ Flash ] Sending omr.img.lz4... OK [ Flash ] Sending prism.img.lz4... OK [ Flash ] Sending optics.img.lz4... OK [ Flash ] Flashing done (time - 00:05:32) [ Flash ] |
10-15-2020, 17:05 | #1597 (permalink) |
No Life Poster Join Date: Sep 2008 Location: kutch, gujarat, india
Member: 852566 Status: Offline Thanks Meter: 464 | oppo f11 pro password reset successful Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: E0529BBDE36677BE, ,FW Ver.: 02.53 CMD Pullup Level:1813 mV CMD Active Level:1866 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100335636434D4202FF5E6AC2956F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 09/2018 Rev.0x2 eMMC NAME: 3V6CMB , S/N: 4284377794 eMMC NAME (HEX): 335636434D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 487 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 3V6CMB_4284377794_20201015_1643.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0083800000 (5.203GB) Short EXT fs info: Size: 5.120GB Block size: 4.0KB Inode size: 256 Inodes: 335872 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x01EB800000 (108.742GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: E0529BBDE36677BE, ,FW Ver.: 02.53 CMD Pullup Level:1812 mV CMD Active Level:1867 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100335636434D4202FF5E6AC2956F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 09/2018 Rev.0x2 eMMC NAME: 3V6CMB , S/N: 4284377794 eMMC NAME (HEX): 335636434D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB , 0xE8F6000 pages , 0x1D1EC00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 487 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01EB800000 (108.742GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x01D0800000 (432.0MB) Erasing... Done. --------------------------------------------- Done. |
10-15-2020, 17:07 | #1598 (permalink) |
Member: 852566 Status: Offline Thanks Meter: 464 | oppo A1K password reset successful Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: E0529BBDE36677BE, ,FW Ver.: 02.53 CMD Pullup Level:1812 mV CMD Active Level:1864 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: E0529BBDE36677BE, ,FW Ver.: 02.53 CMD Pullup Level:1811 mV CMD Active Level:1864 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: E0529BBDE36677BE, ,FW Ver.: 02.53 CMD Pullup Level:1811 mV CMD Active Level:1866 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D420307189695B6A9 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 119051925 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1406 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01BB800000 (22.132GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x01A0800000 (432.0MB) Erasing... Done. --------------------------------------------- Done. |
10-17-2020, 17:45 | #1599 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Samsung j700h/ds frp reset Code: UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J700H/DS Software version: 41.2 Searching Samsung USB Flash interface... COM12 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.41.2 |
10-21-2020, 10:05 | #1600 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | SAMSUNG B360E Read User Lock Code: UNLOCK INSTRUCTIONS: Flash mode: COM Port does not matter, phone will be detect automatically. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect the phone in flash mode (Press '1' button and connect USB cable). Normal mode: 1. Connect powered on phone to USB, choose correct COM port in port settings. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read User Lock Selected model: SM-B360E Selected port: COM15 SCI USB2Serial Software version: 41.2 Waiting phone... detected COM15 Sending FDL... OK Reconnecting phone... OK Sending FDL2... OK Reading data from phone ... OK Phone lock: 00171997 (OFF) Done with Samsung Tool PRO v.41.2 |
10-21-2020, 10:06 | #1601 (permalink) |
Member: 2944109 Status: Offline Thanks Meter: 656 | Samsung Grand Prime + (SM-G532F) FRP Reset Code: UNLOCK INSTRUCTIONS: Direct unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To read security codes (without root permissions): 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Reset FRP Selected model: SM-G532F Software version: 41.2 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 PDA version: G532FXWU1AQA1 CSC version: G532FOJV1AQA1 Phone version: G532FXXU1APL1 Product code: SM-G532FMDDXSG CSC country code: UAE CSC sales code: XSG Phone SN: RV8XXXXXMKA IMEI: 35223XXXXXXX353 HW version: MP 0.300 RF cal date: 20181022 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-01-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.41.2 |
10-21-2020, 10:42 | #1602 (permalink) |
Banned Join Date: Jan 2019 Location: tajikistan kulob
Member: 2889825 Status: Offline Sonork: 100.650600 Thanks Meter: 117 | Sm-j410f u2 unlock done with z3x UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J410F Selected port: COM11 USB Serial Port Software version: 41.3 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J410F Android version: 8.1.0 PDA version: J410FXXS2ATI1 CSC version: J410FOJM2ASL1 Phone version: J410FXXU2ASF2 Product code: SM-J410FZDDMID CSC country code: Iraq CSC sales code: MID Phone SN: XXXXXXXXXXX IMEI: XXXXXXXXXXXXXXXXX HW version: MP 0.200B RF cal date: 2019.02.01 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2020-09-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Searching Samsung diag port... detected COM27 Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM3 detected Reading data from phone... OK Calculating... Searching server... OK Waiting for server answer... OK Freeze code: XXXXXXXX NET lock: XXXXXXXX SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.3 |
The Following User Says Thank You to sunatullo4142 For This Useful Post: |
10-21-2020, 11:18 | #1603 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Balkan Age: 47
Member: 41794 Status: Offline Thanks Meter: 46 | SM-G965U U7 Sprint unlock OK Code: Waiting ADB device... OK Reading phone info... Model: SM-G965U Android version: 10 PDA version: G965USQS7DTE1 CSC version: G965UOYN7DTE1 Phone version: G965USQU7ASJ1 Product code: SM-G965UZKASPR CSC country code: USA CSC sales code: SPR Phone SN: RF8K3049Q7V IMEI: 356420091693523 HW version: REV1.1 RF cal date: 2018.03.15 Chip name: SDM845 Modem board: SDM845 Security patch: 2020-05-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Checking network lock status... LOCKED Reading data from phone... OK Searching server... OK Waiting for server answer... OK Writing data to phone... OK Checking network lock status... UNLOCKED Rebooting phone... OK Done with Samsung Tool PRO v.41.3 |
10-21-2020, 15:52 | #1604 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | Operation: Unlock Selected model: SM-G960U Software version: 41.2 Checking Login and Password... OK Ballance: 24 crd. You have 24 credit(s) left. This operation takes 6 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960U Android version: 8.0.0 PDA version: G960USQS2ARF4 CSC version: G960UOYN2ARF4 Phone version: G960USQS2ARF4 Product code: SM2G960UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R58K607PGWB IMEI: 356915XXXXX6526 HW version: REV1.1 RF cal date: 2018.06.04 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Searching Samsung diag port... detected COM15 Reading phone info... OK Reading data from phone... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.2 |
