12-03-2018, 08:59 | #136 (permalink) |
Freak Poster Join Date: Feb 2018 Location: South Africa Age: 26
Member: 2808949 Status: Offline Thanks Meter: 75 | A320fl frp Sent from my SM-A605F using Tapatalk |
The Following User Says Thank You to jamilahmed12315 For This Useful Post: |
12-03-2018, 10:41 | #137 (permalink) |
Freak Poster Join Date: Oct 2016 Location: India
Member: 2632043 Status: Offline Thanks Meter: 244 | J701F U6 FRP done Step-1. Pls 1St Flash combintion File COMBINATION_OLB_FA70_J701FXXU6ARH1 Step-2. after flash AP file(untick userdata) J701FDDU6BRI1_J701FODD6BRI1_INS phone start without asking gmail id |
The Following 3 Users Say Thank You to JPS784695 For This Useful Post: |
12-03-2018, 12:30 | #138 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2505939 Status: Offline Sonork: [email protected] Thanks Meter: 0 | tnx bro . |
12-04-2018, 08:21 | #139 (permalink) |
No Life Poster Join Date: Jan 2013 Location: searching........ Age: 38
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Samsung J6 J600f Network unlock Done Samsung J6 J600f Network unlock Done Operation: Read Codes via Server Selected model: SM-J600F Software version: 34.3 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J600F Android version: 8.0.0 PDA version: J600FXXU1ARE2 CSC version: J600FOJM1ARDL Phone version: J600FXXU1ARDL Product code: SM-J600FZDGKSA CSC country code: KSA CSC sales code: KSA Phone SN: RF8K52ZFMAN IMEI: 357060091966476 HW version: REV0.3A RF cal date: 20180526 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-05-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,NETWORK_LOCKED Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 42575286 NET lock: 69741953 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.3 |
12-04-2018, 08:50 | #140 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Samsung j8 J810F Network Unlock done By Z3X Box Samsung j8 J810F Network Unlock done Operation: Read Codes via Server Selected model: SM-J810F Selected port: COM3 Prolific USB-to-Serial Comm Port Software version: 34.3 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J810F Android version: 8.0.0 PDA version: J810FJXU1ARG2 CSC version: J810FOJM1ARH1 Phone version: J810FXXU1ARF2 Product code: SM-J810FZKGKSA CSC country code: KSA CSC sales code: KSA Phone SN: R58K72HR4TR IMEI: 359123091172251 HW version: MP 0.500 RF cal date: 2018.07.16 Chip name: SDM450 Modem board: SDM450 Security patch: 2018-07-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 04606372 NET lock: 46092858 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.3 |
The Following User Says Thank You to jkmobile53 For This Useful Post: |
12-05-2018, 17:30 | #141 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Online Sonork: 100.1638403 Thanks Meter: 34 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair DRK Selected model: SM-G925F Software version: 34.3 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM10 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXU5EQJ1 Platform: exynos7420 Boot serial: 0715f77cb2c62336 Product board: zerolte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.34.3 |
12-05-2018, 17:31 | #142 (permalink) |
Member: 1960717 Status: Online Sonork: 100.1638403 Thanks Meter: 34 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair DRK Selected model: SM-G925F Software version: 34.3 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM10 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXU5EQJ1 Platform: exynos7420 Boot serial: 0715f77cb2c62336 Product board: zerolte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.34.3 ????????? |
12-06-2018, 11:05 | #143 (permalink) |
Insane Poster Join Date: Sep 2008 Location: Karakaj
Member: 856194 Status: Offline Thanks Meter: 5 | Operation: Read Codes [ 06-Dec-18 10:13:57 ] Selected model: GT-S5610 [ 06-Dec-18 10:13:58 ] Selected port: COM7 USB Serial Port [ 06-Dec-18 10:13:58 ] Software version: 34.3 [ 06-Dec-18 10:13:58 ] [ 06-Dec-18 10:14:00 ] Connect phone and press power button... Phone detected [ 06-Dec-18 10:14:17 ] Switching phone to TAT mode... OK [ 06-Dec-18 10:14:21 ] Reading phone info... OK [ 06-Dec-18 10:14:21 ] Phone version: S5610XXKL1 [ 06-Dec-18 10:14:21 ] IMEI: 35817304385949 [ 06-Dec-18 10:14:22 ] Phone SN: R21C12H2FM [ 06-Dec-18 10:14:22 ] Phone BT: B0:EC:71:BF:6E:85 [ 06-Dec-18 10:14:22 ] Reading security... OK [ 06-Dec-18 10:14:24 ] Please wait, calculating codes... OK [ 06-Dec-18 10:14:24 ] Freeze code: 21246180 [ 06-Dec-18 10:14:24 ] NET lock: 52867100 [ 06-Dec-18 10:14:25 ] SUB lock: 00000000 [ 06-Dec-18 10:14:25 ] SP lock: 00000000 [ 06-Dec-18 10:14:25 ] CP lock: 00000000 [ 06-Dec-18 10:14:26 ] Multi lock: 00000000 [ 06-Dec-18 10:14:26 ] Phone lock: 00000000 [ 06-Dec-18 10:14:27 ] [ 06-Dec-18 10:15:36 ] Operation: Unlock [ 06-Dec-18 10:15:36 ] Selected model: GT-S5610 [ 06-Dec-18 10:15:36 ] Selected port: COM7 USB Serial Port [ 06-Dec-18 10:15:36 ] Software version: 34.3 [ 06-Dec-18 10:15:36 ] [ 06-Dec-18 10:15:39 ] Connect phone and press power button... Phone detected [ 06-Dec-18 10:15:56 ] Switching phone to TAT mode... OK [ 06-Dec-18 10:15:59 ] Reading phone info... OK [ 06-Dec-18 10:16:00 ] Phone version: S5610XXKL1 [ 06-Dec-18 10:16:00 ] IMEI: 35817304385949 [ 06-Dec-18 10:16:00 ] Phone SN: R21C12H2FM [ 06-Dec-18 10:16:01 ] Phone BT: B0:EC:71:BF:6E:85 [ 06-Dec-18 10:16:01 ] Reading security... OK [ 06-Dec-18 10:16:02 ] Unlocking... OK [ 06-Dec-18 10:16:03 ] Rebooting phone... OK [ 06-Dec-18 10:16:03 ] Unlock done [ 06-Dec-18 10:16:04 ] |
12-06-2018, 13:31 | #144 (permalink) |
No Life Poster Join Date: Dec 2016 Location: .
Member: 2659717 Status: Offline Thanks Meter: 487 | SM-G960F Read Codes Done Operation: Read Codes via Server Selected model: SM-G960F Software version: 34.3 Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 8.0.0 PDA version: G960FXXS1BRF3 CSC version: G960FOXM1BRE3 Phone version: G960FXXU1BRE3 Product code: SM-G960FZKAXEU CSC country code: UK & IRE CSC sales code: XEU Phone SN: R58K70QA4YM IMEI: 359664090014085 HW version: MP 0.900 RF cal date: 20180705 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: ABSENT Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 19574263 NET lock: 63039520 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.3 |
12-06-2018, 13:48 | #145 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | SM-B360E Repair / Patch IMEI Done :) Code: [ 12/6/2018 4:32:32 PM ] Operation: Repair [ 12/6/2018 4:32:32 PM ] Selected model: SM-B360E [ 12/6/2018 4:32:32 PM ] Software version: 34.3 [ 12/6/2018 4:32:32 PM ] [ 12/6/2018 4:32:32 PM ] [ 12/6/2018 4:32:34 PM ] Waiting phone... detected COM22 [ 12/6/2018 4:32:35 PM ] Sending FDL... OK [ 12/6/2018 4:32:35 PM ] Reconnecting phone... OK [ 12/6/2018 4:32:36 PM ] Sending FDL2... OK [ 12/6/2018 4:32:37 PM ] Reading NV... OK [ 12/6/2018 4:32:40 PM ] Checking NV... OK [ 12/6/2018 4:32:40 PM ] IMEI: 000000000000000 [ 12/6/2018 4:32:40 PM ] IMEI 2: 000000000000000 [ 12/6/2018 4:32:41 PM ] Phone HW: [ 12/6/2018 4:32:41 PM ] Product code: [ 12/6/2018 4:32:41 PM ] Phone SN: [ 12/6/2018 4:32:42 PM ] Sending NV... OK [ 12/6/2018 4:32:44 PM ] Repair done Code: [ 12/6/2018 4:40:58 PM ] Operation: Patch Certificate [ 12/6/2018 4:40:58 PM ] Selected model: SM-B360E [ 12/6/2018 4:40:58 PM ] Software version: 34.3 [ 12/6/2018 4:40:58 PM ] [ 12/6/2018 4:41:00 PM ] Waiting phone... [ 12/6/2018 4:41:01 PM ] Operation aborted [ 12/6/2018 4:41:01 PM ] [ 12/6/2018 4:41:13 PM ] Operation: Patch Certificate [ 12/6/2018 4:41:13 PM ] Selected model: SM-B360E [ 12/6/2018 4:41:14 PM ] Software version: 34.3 [ 12/6/2018 4:41:14 PM ] [ 12/6/2018 4:41:15 PM ] Waiting phone... detected COM22 [ 12/6/2018 4:41:16 PM ] Sending FDL... OK [ 12/6/2018 4:41:17 PM ] Reconnecting phone... OK [ 12/6/2018 4:41:17 PM ] Sending FDL2... OK [ 12/6/2018 4:41:19 PM ] Reading data from phone ... OK [ 12/6/2018 4:47:08 PM ] Writing data to phone... OK [ 12/6/2018 4:49:45 PM ] Patching CERT check... done |
12-06-2018, 15:25 | #146 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Kamber, Sindh, Pakistan Age: 36
Member: 1983780 Status: Offline Thanks Meter: 353 | SM-c7108 Frp Bypass in 2 second. Samsung Galaxy C8 SM-C7108 7.0 FRP Bypass in 2 second, select c5000 then click on Reset FRP/React/EE no risk. Operation: Reset FRP/React/EE Selected model: SM-C5000 Software version: 34.3 Searching Samsung USB Flash interface... COM12 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.34.3 |
The Following User Says Thank You to Ayaz Hussain For This Useful Post: |
12-06-2018, 15:56 | #147 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | j337vpp unlocked Operation: Unlock Selected model: SM-J337VPP Software version: 34.3 Checking Login and Password... OK Ballance: 28 crd. You have 28 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J337VPP Android version: 8.0.0 PDA version: J337VPPVRU1ARE6 CSC version: J337VPPVZW1ARE6 Phone version: J337VPPVRU1ARE6 Product code: SM2J337VZSPVZW CSC country code: USA CSC sales code: VZW Phone SN: R28K633489J IMEI: 355049090437953 HW version: J337V.04 RF cal date: 20180628 Chip name: EXYNOS7884A Modem board: SHANNON327 Security patch: 2018-06-01 Boot Warranty bit: 0 SIM State: ABSENT Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Unlocking... OK Unlock done Done with Samsung Tool PRO v.34.3 |
12-07-2018, 20:16 | #148 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2643497 Status: Offline Thanks Meter: 6 | gt-i9000 flash add arabic done [CODE][[ 07/12/2018 17:24:10 ] Operation: Flash [ 07/12/2018 17:24:10 ] Selected model: GT-I9000 [ 07/12/2018 17:24:10 ] Software version: 34.3 [ 07/12/2018 17:24:10 ] [ 07/12/2018 17:24:10 ] File analysis... OK [ 07/12/2018 17:24:11 ] Total file size: 0x11E1C304 (286 Mb) [ 07/12/2018 17:24:11 ] Searching USB Flash interface... COM43 detected [ 07/12/2018 17:24:11 ] Setup connection... OK [ 07/12/2018 17:24:12 ] Reading PIT from phone... OK [ 07/12/2018 17:24:12 ] Sending boot.bin... OK [ 07/12/2018 17:24:13 ] Sending cache.rfs... OK [ 07/12/2018 17:24:18 ] Sending factoryfs.rfs... OK [ 07/12/2018 17:25:54 ] Sending modem.bin... OK [ 07/12/2018 17:25:58 ] Sending param.lfs... OK [ 07/12/2018 17:25:59 ] Sending Sbl.bin... OK [ 07/12/2018 17:26:00 ] Sending zImage... OK [ 07/12/2018 17:26:03 ] Flashing done (time - 00:01:51) [ 07/12/2018 17:26:04 ] /CODE] |
12-08-2018, 00:48 | #149 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | Operation: Unlock Selected model: SM-G920T1 Selected port: COM120 SAMSUNG Mobile USB Serial Port Software version: 34.3 Waiting ADB device... OK Reading phone info... Model: SM-G920T1 Android version: 7.0 PDA version: G920T1UVS6FRC1 CSC version: G920T1TMB6FRC1 Phone version: G920T1UVS6FRC1 Product code: SM2G920TRKATMB CSC country code: USA CSC sales code: TMB Phone SN: R58HB41PSXN IMEI: 355092080097478 HW version: REV1.0 RF cal date: 20161118 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-03-01 Boot Warranty bit: 1 SIM State: SIM_SERVICE_PROVIDER_LOCKED Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: D8 BB 43 2D 76 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.3 |
