11-06-2020, 13:37 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Torredembarra - Spain Age: 48
Member: 84456 Status: Offline Thanks Meter: 6 | problem flashing an a30s [Answered] FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A307FN Software version: 41.8 File analysis... OK Total file size: 0x190850678 (6408 Mb) Searching USB Flash interface... COM4 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.41.8 I download pit files for this model but the same problem Aby help please. Thanks in advance |
11-07-2020, 09:39 | #3 (permalink) |
Member: 84456 Status: Offline Thanks Meter: 6 | Hi support! The files i tried are there from support A307GTVJU4BTG5_OWO4BTG2 A307GTVJU3ATA2_OWA3ATA1 and donwload pit files from here https://gsm-flash.com/samsung-galaxy...download-a307/ and the message in the phone is: SECURE CHECK FAIL: (PIT) Thanks for support |
11-07-2020, 10:19 | #5 (permalink) |
Member: 84456 Status: Offline Thanks Meter: 6 | yes man, i see the mistake ten minutes ago. Then flash this from support A307FNXXU2BTG1_OJM2BTG2 but the same problem Captura de pantalla samsungtool.png IMG_2742.jpg |
04-24-2022, 19:34 | #14 (permalink) |
No Life Poster Join Date: Mar 2008 Location: -----( DUBAI )-----
Member: 716065 Status: Offline Sonork: NOT User Sonork Thanks Meter: 353 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A307FN Software version: 44.0 File analysis... OK Total file size: 0x18F867CCE (6392 Mb) Searching USB Flash interface... COM12 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.44.0 [SM-A307FN,Flash] |
04-24-2022, 20:10 | #15 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,063 | Quote:
