12-29-2009, 12:36 | #1 (permalink) | ||||||||
Insane Poster Join Date: Jun 2006
Member: 289366 Status: Offline Thanks Meter: 32 | Problem in unlocking Samsung T469 Gravity 2 Search Phone via Com Port Quote:
Flash Boot Files came from Support Area using MultiLoader 5.60 (BOOT_T469UVID5) Flash again the Unit using Z3X with Flash File came from Support Area Quote:
Searching the Phone using Com Port Quote:
Searching the Phone using Qualcomm Mode Quote:
Please Help me to Put the Phone Back to Normal State... ASAP... TIA br, marcsantos | ||||||||
01-03-2010, 12:37 | #7 (permalink) | |
Freak Poster Join Date: Oct 2004 Location: www.dalatgsm.com/forums
Member: 87020 Status: Offline Thanks Meter: 9 | Quote:
I HAVE same problem , then when i flash t469UVID5 Searching phone at COM interface... ok Model: T469 SW: T469UVIG4 Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVIG4 Reading data from phone... error Searching Samsung USB Flash interface... detected (COM42) Sending file 1 of 4... sended Sending file 2 of 4... Error (Boot mismatch) NOW can't power on,pls help w | |
01-03-2010, 13:04 | #8 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | dun flash patch again,wait for team check flash file patch attention post from marcsantos(Phone now Stuck in Flipped Sideway Screen) Last edited by freedomqn; 01-03-2010 at 13:11. |
01-09-2010, 14:04 | #12 (permalink) |
Insane Poster Join Date: Aug 2005 Location: BANGLADESH Age: 50
Member: 170700 Status: Offline Thanks Meter: 8 | samsung T469 Flash ok but Unk=lock Problem Checking ports... ok Searching phone at COM interface... unable to find phone Checking ports... ok Searching Qualcomm USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Searching Qualcomm USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Reading file as T469... ok Model: T469 Version: T469UVID5 Searching Samsung USB Flash interface... detected (COM15) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:07:13) Searching Samsung USB Flash interface... detected (COM15) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:07:29) Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading data from phone... error Searching Samsung USB interface... not found USB interface required Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading data from phone... error Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading Codes as MSL2... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Unlock as MSL2 Direct... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading Codes as MSL2... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Unlock as MSL2 Direct... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Unlock as MSL2 Direct... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading Codes as MSL2... error (secure damaged) Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading data from phone... error |
01-09-2010, 14:05 | #13 (permalink) |
Member: 170700 Status: Offline Thanks Meter: 8 | Sumsung t469 flash ok but unlock problem Checking ports... ok Searching phone at COM interface... unable to find phone Checking ports... ok Searching Qualcomm USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Searching Qualcomm USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Reading file as T469... ok Model: T469 Version: T469UVID5 Searching Samsung USB Flash interface... detected (COM15) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:07:13) Searching Samsung USB Flash interface... detected (COM15) Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 00:07:29) Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading data from phone... error Searching Samsung USB interface... not found USB interface required Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading data from phone... error Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading Codes as MSL2... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Unlock as MSL2 Direct... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading Codes as MSL2... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Unlock as MSL2 Direct... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Unlock as MSL2 Direct... error (secure damaged) Searching Qualcomm USB interface... not found Searching Samsung USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading Codes as MSL2... error (secure damaged) Searching Qualcomm USB interface... not found Searching phone at COM interface... ok Model: T469 SW: T469UVID5 Reading data from phone... error |
01-09-2010, 14:15 | #14 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
and next time use search button. this problem already disccussed | |
01-09-2010, 15:21 | #15 (permalink) |
Registered User Join Date: Jan 2008
Member: 692785 Status: Offline Thanks Meter: 20 | procedure for unlocking this phone... 1st full reset phone type *2767*3855# without sim for direct unlock select t649 no images selected on screen ist phone t469 and t649 is the same.. no need to flash. |
The Following User Says Thank You to leepswit For This Useful Post: |
Problem in unlocking Samsung U600 | brijmehta1 | UST Pro II | 9 | 07-16-2008 20:20 |
Problem in unlocking Samsung Z170 | brijmehta1 | Easy-Unlocker | 2 | 02-10-2008 21:34 |
