06-15-2020, 17:57 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Read PIT error SM-A520f [Answered] Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A520F Software version: 40.3 Searching USB Flash interface... COM31 detected Setup connection... OK Reading PIT file... error Done with Samsung Tool PRO v.40.3 I am stuck here. please advice. |
06-15-2020, 18:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 483 | Read pit error is alwayes hardware faulty but sometimes i get rid of it by changing usb cable but it's in rare case try to change usb cable as well as usb port otherwise it's emmc problem Best Regards | Bayaaa[/B] |
06-16-2020, 07:45 | #4 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,566 | what firmware in phone before flashing? what firmware you trying to flashing in to phone? what the status of phone? why you update firmware? what you see on display at the moment of error of flashing? |
