01-06-2015, 18:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | S5570 no answare solution for unlock Problem Selected model: S5570 Selected port: COM40 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.18.2 Done with Samsung Tool v.18.2 Solution... If you got "Reading security ...error,Security data not found" errors, then you must check "New" in unlock options. micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press "Unlock" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choise phone usb. 3. Type *#197328640#, select: Common - Diag Config - USB diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. Tested BY RS |
The Following User Says Thank You to Rotan Sarkar For This Useful Post: |
