Old 11-07-2016, 13:15   #1 (permalink)
Member: 9584
Thanks Meter: 31
a310f frp unlock
Hi i want to unlock frp on a310 . i downloaded the combination file but i cannot choose as zip file . i unzipped it and it has 2 files inside how to put this to Software the big one i choosed as pda buit the second one i dont know how to put it. i wanted to choose it as boot file but i dont want to destroy the phone
Old 11-07-2016, 20:48   #2 (permalink)
Member: 1868823
Thanks Meter: 47
flash the first one the big one if not working flash the other one too in pda
Old 11-07-2016, 22:24   #3 (permalink)
Member: 9584
Thanks Meter: 31
it flashed the small one but adb is not activated i tried to big one and i get
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-A310F
Software version: 27.0
File analysis... ok
Total file size: 0x3A915088 (937 Mb)
Searching USB Flash interface... COM5 detected
Setup connection... ok
Reading PIT from phone... ok
Sending sboot.bin... error timeout
Done with Samsung Tool PRO v.27.0
The Following User Says Thank You to darkeye For This Useful Post:
Old 11-24-2016, 02:57   #4 (permalink)
Member: 2632572
Sonork: 404 Not Found
DO NOT CHOOSE THE SMALL FILE AS BOOT!
It will kill your phone and you'll have to restore it with the official firmware.
Old 12-11-2016, 01:11   #5 (permalink)
Member: 895943
Sonork: zimonjic
Thanks Meter: 15
a310f frp not working
Try with combination file from support area but no luck seams frp unlock not working for latest security:
Operation: Flash
Software version: 27.4.2
File analysis... Ok
Total file size: 0x27300D98 (627 Mb)
Searching USB Flash interface... COM6 detected
Setup connection... Ok
Reading PIT from phone... Ok
Done with Samsung Tool PRO v.27.4.2
hope so new update will support latest security...and z3x will be first
Old 12-11-2016, 08:00   #6 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: Uninstalled
Thanks Meter: 1,090
FLASH INSTRUCTIONS:
Operation: Flash
File analysis... ok
flash without sboot with z3x
Old 02-11-2017, 11:17   #7 (permalink)
Member: 2451167
Thanks Meter: 65
if u flash without sboot the set dont boot anymore
Old 02-11-2017, 23:16   #8 (permalink)
Member: 9584
Thanks Meter: 31
can somebody give a clear instructions to remove frp on a310f. i saw lots of people have problems with it. why dont z3x team give a clear instruction? which files to use ? should we downgrade. if yes which combination file?
thanks a lot
Old 02-11-2017, 23:46   #9 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
thanks a lot
Please check this NO BOX method. It is simple and no combination or rooting required:
http://forum.gsmhosting.com/vbb/f453.../#post12280856
PLEASE CLICK ON THE THANKS BUTTON IF THE POST IS HELPFULL
The Following User Says Thank You to GalaxyVibe For This Useful Post:
Old 03-03-2017, 13:38   #10 (permalink)
crysst's Avatar
Member: 48215
Thanks Meter: 19
Afther few try when i receive the sboot eroor, i find a combination for my A310 who work, afther that phone start with FACTORY BINARY and some strange menu, the frp on the soft say it is done, i make factory reset from the seting but phone still frp on, is something wrong?
Old 03-03-2017, 13:55   #11 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
After Factory binary mode Frp reset keep usb debugging on and flash your original firmware and Reset Frp again, when menu works Enable OEM then make factory reset.
Old 03-03-2017, 14:16   #12 (permalink)
crysst's Avatar
Member: 48215
Thanks Meter: 19
OK, let me see if i understand
1. factory binary is ok
2. in factory binary do frp reset
3. swich in flash mode and flash original firmware
4. now i have adb and reset again frp
5. go setings and make factory reset
6. done
Old 03-03-2017, 14:39   #13 (permalink)
crysst's Avatar
Member: 48215
Thanks Meter: 19
like i suspect, not working, afther flash original firmware no adb port
Old 11-12-2019, 15:51   #14 (permalink)
Member: 1159475
Sonork: multan
Thanks Meter: 68
Samsung SM-A310F 7.0 FRP Remove With Odin
Samsung SM-A310F FRP Unlock File | Remove FRP SM-A310F With Odin | A310F U4 FRP Bypass | U3 FRP Remove SM-a310F With Odin | 7.0 FRP Remove
Page generated in 0.21529 seconds with 8 queries
