Old 10-01-2016, 14:26   #1 (permalink)
Member: 2189329
Thanks Meter: 8
LG MS428 pattern lock
I have a LG MS428 and cant remove pattern lock. Really not that familar with the LG line Yet. the phone is Metro PCS.
I put the phone in download mode.
LG 2-3G Tool v9.25
supported models: 1380
Reading timeout, check cable
Error Code: ReadInfo,1,1
Elapsed: 3 secs. --> (v9.25)
I cant find a root for this phone?????
Old 10-01-2016, 16:32   #2 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Hi,
Select H900 for example,
Put phone in download mode,
Press Reset Screen Lock button
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 10-02-2016, 02:40   #3 (permalink)
Member: 2189329
Thanks Meter: 8
this is what i keep getting
LG 2-3G Tool v9.25
Not detect phone! Please manual select port or reboot PC!
does the phone have to be rooted?
Should i be connected to the z3x box or PC?
Old 10-02-2016, 07:39   #4 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
LG 2-3G Tool v9.25
Should be connected to the PC
Search phone
The Following User Says Thank You to mbiborna For This Useful Post:
Old 10-02-2016, 07:59   #5 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
You install LG driver?
PC detect LG port?
Old 10-02-2016, 14:52   #6 (permalink)
Member: 2189329
Thanks Meter: 8
Mode: Emergency
Model: MS428
Elapsed: 2 secs. --> (v9.25)
Phone mode is DOWNLOAD
Start reset screen locks...
Model name: LGMS428
Software verion: MS42810c
Android verion: 6.0.1
IMEI: 358479073352084
Truncate file 0...
Laf flash ext4 error: could not find inode for "/system/backuppin.key".
Laf flash ext4 error: [TruncateFile] could not find inode.
Truncate file 1...
Laf flash ext4 error: could not find inode for "/system/gesture.key".
Truncate file 2...
Laf flash ext4 error: could not find inode for "/system/password.key".
Truncate file 3... done
Truncate file 4... done
Truncate file 5... done
Screen locks removed.
Elapsed: 42 secs. --> (v9.25)
It has a APP called 360 security and I think that is what gives the pattern lock. Also now its stuck on the boot logo Metro Pc.
when i try to factory reset the phone the program just locks up.
Old 10-02-2016, 15:20   #7 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
If phone still Goes download mode Flash same Software verion: MS42810c
Post result.
Old 10-02-2016, 17:27   #8 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
You need reflash phone with checked:
flash in direct mode
erase user data after flash
360 security this not standard app.
Old 10-02-2016, 20:46   #9 (permalink)
Member: 2189329
Thanks Meter: 8
I reflashed the firmware and now it boots ok but still have pattern lock with 360 security.
Old 10-02-2016, 20:48   #10 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Please post reflash log here.
Old 10-02-2016, 21:35   #11 (permalink)
Member: 2189329
Thanks Meter: 8
Mode: Emergency
Model: MS428
Start flashing.
Open KDZ File : C:\Users\NEW\Desktop\LG MS428\MS42810c_00_0514.kdz
Model : LGMS428
SwVersion : MS42810c
BuildTime : 0000-00-00 00:00:00
Total Files : 52
Model name: LGMS428
Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED].
Start indirect download mode.
Sending image...
Verifying image...
Checking image...
Flashing image...
Done.
Elapsed: 219 secs. --> (v9.25)
Old 10-02-2016, 21:52   #12 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Mode: Emergency
Model: MS428
Start flashing.
Model : LGMS428
Total Files : 52
Model name: LGMS428
Sending image...
Verifying image...
Checking image...
Flashing image...
Done.
1. This message is debug.
2. I write you in post:
you not make this.
Old 10-02-2016, 23:41   #13 (permalink)
Member: 2189329
Thanks Meter: 8
I was able to remove 360 app security.
1st long press on the settings icon and drag it to the bottom bar.
2nd long press the settings icon and look for the 360 app and drag it to the uninstall location at top of screen.
thats it the pattern lock is gone.
I want to thank every body for there help.
Oh by the way how do you unlock this phone.
Old 11-21-2016, 21:36   #14 (permalink)
Member: 1815016
Thanks Meter: 77
Same issue trying to remove PIN lock from same model (normal PIN lock, not "360 security app").
Unable to get comport information , check system
LG 2-3G Tool v9.27
supported models: 1397
Mode: Emergency
Model: MS428
Elapsed: 2 secs. --> (v9.27)
Model name: LGMS428
IMEI:
Truncate file 0...
Truncate file 1...
Truncate file 2...
Elapsed: 50 secs. --> (v9.27)
And phone stuck on Metro PCS logo and does not advance from there.
Assistance needed please
Old 11-22-2016, 20:20   #15 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
LG 2-3G Tool v9.27
Mode: Emergency
Model: MS428
Model name: LGMS428
IMEI:
Truncate file 0...
Truncate file 1...
Truncate file 2...
Reflash phone with latest firmware version. Check in options:
- flash in direct mode
- erase user data after flash.
Page generated in 0.22835 seconds with 8 queries
