05-23-2022, 18:44 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 465 | Samsung A6+ SM-A605FN FRP [Done] UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Reset FRP Selected model: SM-A605FN Software version: 44.4 Searching Samsung modem... detected COM52 Reading phone info... Model: SM-A605FN AP version: A605FNXXU7CUB3 CSC version: A605FNOXM7CUB3 CP version: A605FNXXU7CUB2 OS version: 10 Product code: TPH Phone SN: R58K50B1SWM IMEI: 355612090XXXXXX IMEI2: 355613090XXXXXX Unique number: CGX001B7AA89525 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.4 [SM-A605FN,Reset FRP] |
