07-29-2017, 13:44 | #1 (permalink) |
Junior Member Join Date: Sep 2008 Location: DHAKA BANGLADESH
Member: 853304 Status: Offline Sonork: 100:1602230 Thanks Meter: 7 | samsung g610f unlock done Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZKDMID Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQE4 CSC version: G610FOJV1AQE3 CSC country code: Iraq CSC sales code: MID HW version: MP 0.300 Phone SN: R58J50JF3YV Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-05-01 RF cal date: 20170504 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 95 06 00 00 00 00 00 00 00 00 00 00 E4 10 94 BE Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
11-12-2017, 06:44 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G610F Software version: 29.6 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDKSA Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: KSA CSC sales code: KSA HW version: MP 0.400 Phone SN: R58J64JZDQH Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170621 IMEI: 354772088 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: E7 07 00 00 00 00 00 00 00 00 00 00 88 94 95 EF Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done |
11-25-2017, 11:40 | #3 (permalink) |
Member: 120328 Status: Offline Thanks Meter: 243 | UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G610F Software version: 30.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZKDKSA Phone version: G610FDDU1AQF4 PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: KSA CSC sales code: KSA HW version: MP 0.400 Phone SN: R58JA5XGHZA Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20171027 IMEI: 351692098611 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: E6 05 00 00 00 00 00 00 00 00 00 00 BB 0A 7E 6E Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.0 |
