08-03-2017, 16:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | samsung G950u unlock problem (Tmobile ) Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Selected port: COM147 SAMSUNG Mobile USB Serial Port Software version: 29.0 Checking phone at COM147 no answer from phone Done with Samsung Tool PRO v.29.0 |
08-03-2017, 17:38 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bto read code doesn't support tmobile phones IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
08-03-2017, 18:13 | #3 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | TMO phones that use unlock app are not supported by any box! They can't be done! It has been discussed extensively all over the forums around the world. |
The Following User Says Thank You to jcdes For This Useful Post: |
08-03-2017, 19:41 | #5 (permalink) |
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | Does the phone meet the qualifications for device unlock? Unless it does there is now way. Device eligibility is determined as follows: The device must be a T-Mobile device. The device must not be reported as lost, stolen or blocked to T-Mobile. The account associated with the device must be in good standing. You have requested no more than 2 mobile device unlock codes per line of service in the last 12 months. The device must satisfy all the Postpaid or Prepaid Unlocking terms outlined below. Unlock Eligibility for Monthly Phones and tablets The device must have been active on the T-Mobile network for at least 40 days on the requesting line. If the device was financed using T-Mobile’s Equipment Installment Plan (EIP), then all payments must be satisfied and the device must be paid in full. If the device is on an account that has a service contract term, then at least 18 consecutive monthly payments must have been made or the account was migrated to a no contract rate plan. If the device is associated with a canceled account, then the account balance must be zero. T-Mobile may request proof of purchase or additional information in its discretion and certain other exceptions may apply. Unlock Eligibility for Prepaid Phones and Tablets The device has been active on the T-Mobile network for more than 1 year. If the device has been active for less than 1 year, then the Prepaid account associated with the device must have had more than $25 in refills for basic phones or $100 in refills for smartphones or tablet since device first use date. T-Mobile may request proof of purchase or additional information in its discretion and certain other exceptions may apply. |
