06-30-2016, 14:52 | #16 (permalink) |
No Life Poster Join Date: Apr 2009 Location: >>>JANNAT<<<
Member: 1012319 Status: Offline Thanks Meter: 617 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G935F Software version: 25.8 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZWANEE Phone version: G935FXXU1APB6 PDA version: G935FXXU1APF2 CSC version: G935FNEE1APE2 CSC country code: Nordic CSC sales code: NEE HW version: MP 0.801 Phone S/N: RF8H51ANCZF Modem board: SHANNON335 RF cal date: 20160513 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 91426958 NET lock: 37197205 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.25.8 here is modem file http://forum.gsmhosting.com/vbb/f453...oblem-2104502/ |
The Following 4 Users Say Thank You to sameer525kk For This Useful Post: |
07-30-2016, 16:43 | #17 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Tétouan Age: 38
Member: 2377800 Status: Offline Sonork: nono Thanks Meter: 48 | all users canot unlock pleas use flash file for this date 2016/02/22 |
The Following User Says Thank You to mohacraft For This Useful Post: |
10-04-2016, 09:54 | #18 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | Operation: Unlock Selected model: SM-G935F Software version: 26.9 Searching Samsung modem... detected COM30 Reading phone info... OK Model: SM-G935F AP version: G935FXXU1BPHJ CSC version: G935FEVR1BPH1 CP version: G935FXXU1BPHJ Product code: SM-G935FZKAEVR Phone SN: RF8H70W6MRD Unique number: CE0616067B8DEC3B05 Reading IMEI... OK IMEI: 352204086949726 (SIGN: OK) Reading data from phone... error (0) Done with Samsung Tool PRO v.26.9 wath happend ? |
The Following 3 Users Say Thank You to alunecosu_hd For This Useful Post: |
10-15-2016, 10:14 | #19 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Dhaka,Bangladesh.
Member: 492386 Status: Offline Sonork: 100.1601487 Thanks Meter: 63 | Samsung SM-G935FD unlock done successfully at last.First i try to unlock this set with Z3X latest version 26.9 but it cant.When i click read codes then it show Try downgrade modem if possible and when click on unlock tab then it show unlock failed. Then i try Octopus Samsungtool it show select model manually SM-G935F then try to unlock.It read info when i click to read code it say device is not rooted,Then i oot it with Octopus,it download a root file and flash the phone after restart the phone hang on samsung logo.Then i find the firmware and after found i download it then flash with same firmware version then phone run in normal mode.Then i download rootb file from chainfire CF-Auto-Root-hero2lte-hero2ltexx-smg935f.zip then flash it with Odin tool,now the phone is successfully rooted.Now try with Z3x but same message,try with octopus read code but it fail then click octopus direct unlock button then it show phone unlock done but after restating phone shoe no service then i check the IMEI gone,then i write the security file from the octopus backup folder but then IMEI back but phone is still locked.Now i show a post in gsm forum Then i download the modem file and write it with ODIn select ap tab,it write successfully, Then click the unlock button in Z3X and at last the phone perfectly unlocked.Thanks to markhaines1985. |
10-15-2016, 10:35 | #20 (permalink) |
Member: 492386 Status: Offline Sonork: 100.1601487 Thanks Meter: 63 | Samsung SM-G935FD unlock done successfully at last.First i try to unlock this set with Z3X latest version 26.9 but it cant.When i click read codes then it show Try downgrade modem if possible and when click on unlock tab then it show unlock failed.Then i try Octopus Samsungtool it show select model manually SM-G935F then try to unlock.It read info when i click to read code it say device is not rooted,Then i root it with Octopus,it download a root file and flash the phone after restart the phone hang on samsung logo.Then i find the firmware and after found i download it then flash with same firmware version then phone run in normal mode.Then i download root file from chainfire CF-Auto-Root-hero2lte-hero2ltexx-smg935f.zip then flash it with Odin tool,now the phone is successfully rooted.Now try with Z3x but same message,try with octopus read code but it fail then click octopus direct unlock button then it show phone unlock done but after restating phone shoe no service then i check the IMEI gone,then i write the security file from the octopus backup folder but then IMEI back but phone is still locked.Now i show a post in gsm http://forum.**********.com/vbb/f453...oblem-2104502/ Then i download the modem file and write it with ODIn select ap tab,it write successfully, Then click the unlock button in Z3X and at last the phone perfectly unlocked.Thanks to markhaines1985. |
10-19-2016, 19:25 | #21 (permalink) |
Freak Poster Join Date: Jun 2010 Location: ON Maind
Member: 1326581 Status: Offline Sonork: (((NAEEM))) Thanks Meter: 52 | Searching Samsung modem... detected COM882 Reading phone info... OK Model: SM-G935F AP version: G935FXXU1APD1 CSC version: G935FOJV1APD1 CP version: G935FXXU1BPHJ Product code: SM-G935FEDAXSG Phone SN: R58H8259GSZ Unique number: AD05160238D547524A Reading IMEI... OK IMEI: 357330078860111 (SIGN: OK) Checking hash file... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.26.9 |
The Following 2 Users Say Thank You to (((NAEEM))) For This Useful Post: |
12-23-2016, 09:16 | #23 (permalink) |
Junior Member Join Date: Feb 2015 Location: mysore
Member: 2342018 Status: Offline Thanks Meter: 2 | g935fd Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1APEQ PDA version: G935FXXU1APGO CSC version: G935FOXE1APE1 CSC country code: Russia CSC sales code: SER HW version: Phone SN: RF8H327G0EF Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (decompress error) Done with Samsung Tool PRO v.27.5 |
The Following User Says Thank You to moinrd For This Useful Post: |
03-14-2017, 12:29 | #24 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Punjab India
Member: 687144 Status: Offline Sonork: 1614780 Thanks Meter: 228 | samsung G935FD after unlock show no service ....... Emergency call |
The Following 2 Users Say Thank You to Maninder_111 For This Useful Post: |
05-10-2017, 14:25 | #26 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | Model: SM-G935F Android version: 7.0 Product code: SM-G935FZBAXEU Phone version: G935FXXU1DQC2 PDA version: G935FXXU1DQC4 CSC version: G935FXEU1DQB1 CSC country code: UK & IRE CSC sales code: XEU HW version: MP 0.801 Phone SN: RF8J100866K Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-02-01 RF cal date: 20170102 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 09 79 44 53 9B 66 52 5D 5E 38 3D F4 A6 9D B3 69 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.1 b.r. kalpesh varia |
The Following User Says Thank You to PARMATMA For This Useful Post: |
05-29-2017, 10:56 | #27 (permalink) | |
Major Poster Join Date: Mar 2014
Member: 2154108 Status: Offline Sonork: 100.1622674 Thanks Meter: 5 | Quote:
How to root this phone with ver 7.0? please.... | |
The Following User Says Thank You to udhai For This Useful Post: |
10-10-2017, 05:13 | #29 (permalink) |
Crazy Poster Join Date: Aug 2009
Member: 1107281 Status: Offline Sonork: zzz Thanks Meter: 2 | Searching Samsung modem... detected COM59 Reading phone info... OK Model: SM-G935FD AP version: G935FXXU1BPLB CSC version: G935FOJV1BPK2 CP version: G935FXXU1BPJJ Product code: SM-G935FZBUKSA Phone SN: RF8J21XE51E Unique number: CE01171140FB0C1B0C Reading IMEI... OK IMEI: 358xxxxxxxxxx (SIGN: OK) IMEI 2: 358xxxxxxxxxxx (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... OK Reading data from phone... OK Modem board: SHANNON335 HWID: E0 45 EC 30 7E EE DB AF 6E 24 B7 37 E5 AC A8 D6 Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:06) Freeze code: 92859131 NET lock: 24062842 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 no need rroot thanks z3x team for update.... br |
The Following User Says Thank You to benny30 For This Useful Post: |
12-27-2017, 12:59 | #30 (permalink) |
Freak Poster Join Date: Jun 2005 Location: pakistan
Member: 155330 Status: Offline Sonork: 100.1585247 Thanks Meter: 7 | unlock sccessfully Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 Product code: SM-G935FZKAVOD Phone version: G935FXXU1APB2 PDA version: G935FXXS1DQKH CSC version: G935FVFG1DQI1 CSC country code: UK CSC sales code: VOD HW version: MP 0.801 Phone SN: RF8H40AW7EK Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-11-01 RF cal date: 20160403 IMEI: 358809079765162 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 6D 25 99 1D A2 A4 B0 D6 4E 45 95 88 AE D0 59 88 Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:05) Freeze code: 19495174 NET lock: 39496827 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.2 |
