04-29-2021, 20:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | Samsung Galaxy S9+ unlock error [Answered] Warning! Diag algos will not work if the device has tripped knox! To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button, select 'Unlock via server ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Info Selected model: SM-G965F Software version: 42.10 Searching Samsung modem... detected COM15 Reading phone info... Model: SM-G965F AP version: G965FXXUAETG3 CSC version: G965FOVFAETG3 CP version: G965FXXUAETG3 Product code: VOD Phone SN: R58K80STQPF IMEI: 355327090116391 Unique number: CE0718271C5508501C7E Reading IMEI... OK IMEI: 355327090116*** (SIGN: UNKNOWN) Done with Samsung Tool PRO v.42.10 UNLOCK INSTRUCTIONS: Warning! Diag algos will not work if the device has tripped knox! To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button, select 'Unlock via server ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG Jan 2021] Selected model: SM-G965F Software version: 42.10 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: Android version: PDA version: CSC version: Phone version: Product code: CSC country code: CSC sales code: Phone SN: IMEI: 355327090116*** HW version: RF cal date: Chip name: Modem board: Incorrect model selected Done with Samsung Tool PRO v.42.10 |
04-29-2021, 20:39 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,058 | Hello. Reflash your phone with this firmware and repeat operation. Post result. https://samfrew.com/ru/download/Gala...G965FOXMAETG3/ |
05-01-2021, 09:20 | #3 (permalink) | |
Member: 1638915 Status: Offline Thanks Meter: 432 | Quote:
To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button, select 'Unlock via server ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD Mar 2021] Selected model: SM-G965F Software version: 42.10 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: Android version: PDA version: CSC version: Phone version: Product code: CSC country code: CSC sales code: Phone SN: IMEI: 355327090116391 HW version: RF cal date: Chip name: Modem board: Incorrect model selected Done with Samsung Tool PRO v.42.10 | |
