01-28-2010, 07:58 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 399228 Status: Offline Thanks Meter: 66 | samsung GT s5603 phone lock code help needed. |
01-28-2010, 12:51 | #2 (permalink) |
Member: 399228 Status: Offline Thanks Meter: 66 | I got my answer here: http://forum.gsmhosting.com/vbb/showthread.php?t=912602 .If there is phone lock usb modem will not get detected on normal mode. One can use ca101 cable and flash the handset in download mode. |
The Following 2 Users Say Thank You to amit_varietymob For This Useful Post: |
07-24-2017, 13:13 | #9 (permalink) |
Freak Poster Join Date: Mar 2010 Location: hydrabad sindh
Member: 1266092 Status: Offline Sonork: love Thanks Meter: 17 | UNLOCK INSTRUCTIONS: UART cable: 1. Phone must be powered on. 2. Connect the phone to UART cable. 3. Choose correct COM port in port settings. 4. Check security type ('Old Security' or 'New Security'). 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. USB cable with 'Old Security' option: 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If you got 'Calculating ... error' or 'Reading sysinfo ... access denied' errors, then you must check 'New security' option. USB cable with 'New Security' option: 1. Phone must be powered on. 2. Type *#726872# to switch phone to Samsung USB mode. 3. Connect USB cable, install drivers. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read User Lock Selected model: GT-S5603 Selected port: Software version: 28.1 Searching Samsung modem... detected COM692 Reading phone info... Ok Model: GT-S5603T Phone version: S5603AJJB3 IMEI: ********** Reading phone lock... Ok Phone lock: 15901590 Reading SIM lock... Ok SIM lock: 0000 Done with Samsung Tool PRO v.28.1 |
samsung SGH-F480 PHONE LOCK CODE HELP ME PLS | palav | Samsung Flashers, Software, Firmware. | 3 | 08-13-2014 18:42 |
sam gt-m2513 phone lock code | tanvir_guru | Trident/AGERE Platform | 8 | 11-20-2010 17:26 |
samsung SGH-F480 PHONE LOCK CODE HELP ME PLS | palav | Phone Unlocking Codes & Maps | 3 | 12-05-2009 19:21 |
nokia n73 phone lock code..help needed | math000 | Nokia Hardware & Hardware Repair | 1 | 01-21-2008 06:00 |
Samsung X660 PHONE LOCK CODE HELP | Djordje88 | Trident/AGERE Platform | 6 | 04-07-2007 18:52 |
