03-23-2013, 18:57 | #1 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1559973 Status: Offline Thanks Meter: 35 | samsung i677 unlock easy second:make sure drivers are installed i would recommend you use windows 7 machine as drivers easier to install.. Enter "##634#" number. Input *#7284# code. Select "Modem, USB Diag" option. Press "OK" button. Wait until phone restart. then connect and press read codes. when reach point of searching samsung mode disconnect and reconnect phone and should find port.. Selected model: I8350 Selected port: COM14 SAMSUNG Mobile Modem Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... PDA/CSC version: i677UCKJ1/i677ATTKJ1 Phone version: i677UCKJ1 Phone HW: REV0.6 Cal date: 2012.03.08 Reading IMEI... OK IMEI: 359881040154924 Phone S/N: R21C318RVP Build: M7630A-AAEQMWZM-1.6.002402 Done with Samsung Tool v.14.1 Selected model: I8350 Selected port: COM14 SAMSUNG Mobile Modem Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... PDA/CSC version: i677UCKJ1/i677ATTKJ1 Phone version: i677UCKJ1 Phone HW: REV0.6 Cal date: 2012.03.08 Reading IMEI... OK IMEI: 359881040154924 Phone S/N: R21C318RVP Build: M7630A-AAEQMWZM-1.6.002402 Switching to download mode... OK Searching Samsung modem... detected COM14 Reading data from phone... OK Reading AMSS from phone... OK Switching to normal mode... OK Reading phone info... PDA/CSC version: i677UCKJ1/i677ATTKJ1 Phone version: i677UCKJ1 Phone HW: REV0.6 Cal date: 2012.03.08 Reading IMEI... OK IMEI: 359881040154924 Phone S/N: R21C318RVP Build: M7630A-AAEQMWZM-1.6.002402 Bypass MSL... OK Freeze/Master code: 57139148 NET lock: 75258397 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.14.1 Done with Samsung Tool v.14.1 |
