07-14-2018, 18:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Samsung j7 neo j701m flash firmware success SAMSUNG J7 NEO J701M FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J701M Software version: 33.2 Unpacking file... oK File analysis... OK Total file size: 0xE43BE91B (3651 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:01) Done with Samsung Tool PRO v.33.2 |
The Following User Says Thank You to jseyedanas For This Useful Post: |
