06-15-2022, 11:43 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: TANK PAKISTAN
Member: 2632732 Status: Offline Sonork: 100.1675450 Thanks Meter: 60 | samsung j737s u6 repair+patch done [Done] REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch CERT Jul 2021 Selected model: SM-J737S Software version: 44.8 Waiting ADB device... OK Reading phone info... Model: SM-J737S Android version: 10 PDA version: J737SKSU6CUH1 CSC version: J737SSKC6CUH1 Phone version: J737SKSU6CUH1 Product code: CSC country code: KOREA CSC sales code: SKC Phone SN: R59M100S2Z IMEI: 355064085894456 HW version: J737S.05A RF cal date: 20190103 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2021-09-01 Boot Warranty bit: 1 SIM State: LOADED Checking Super user right... true Root version: 24.3:MAGISKSU Removing patch cert... OK Checking data... OK Searching server... OK Checking server answer... OK Data preparation... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK file+root Method+avalibal whatsapp 03068512298 |
