06-21-2022, 03:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Egypt Age: 40
Member: 1382969 Status: Offline Sonork: 100.1679189 Thanks Meter: 30 | Samsung M-115F u3 FRP failed [Asnwered] To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Reset FRP Selected model: SM-M115F Software version: 44.11 Searching Samsung modem... Operation: Reset FRP Selected model: SM-M115F Software version: 44.11 Searching Samsung modem... Operation: Reset FRP Selected model: SM-M115F Software version: 44.11 Searching Samsung modem... not found Please reboot phone. Disable screenlock(PIN, password, fingerprint and etc...). Disable SIM PIN/PUK code. not found Please reboot phone. Disable screenlock(PIN, password, fingerprint and etc...). Disable SIM PIN/PUK code. detected COM5 Reading phone info... error (0) Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... error (0) Reboot phone and try again. Done with Samsung Tool PRO v.44.11 [SM-M115F,Reset FRP] |
