10-12-2013, 21:50 | #16 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9505_File_for_Unlock_4.2.2.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. |
10-12-2013, 21:54 | #17 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Israel
Member: 1563247 Status: Offline Thanks Meter: 57 | Your phone in download mode? If yes, pull the battery and insaert back, then go to dowload mode again. Have you installed the samsung usb drivers? If not you can downloading from here. Edit: The link. https://mega.co.nz/#!6MkjXYAK!Fo1aQA...UJyDmDhf3nS3Do |
10-12-2013, 22:15 | #19 (permalink) |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | flashed with ( I9505XXUDMH8_I9505OXXDMHA_BTU.zip) firmware not download mode shows !!! KNOX KERNAL LOCK : 0X0 KNOX WARRENTY VOID :0x0 |
10-12-2013, 22:19 | #20 (permalink) |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | now phone in download mode <ID:0/041> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9505_File_for_Unlock_4.2.2.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. but KNOX KERNAL ? will it kill phone ? |
10-12-2013, 22:24 | #21 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | That's pretty much selfexplanatory now. You want be unlocking this one neither debrand or flash different region fw. There is no downgrade too. Br Haltec |
10-12-2013, 22:25 | #22 (permalink) | |
Member: 1563247 Status: Offline Thanks Meter: 57 | No. it wouldn't kill the phone. You just need to flash the unlock file and then do the unlock with z3x. Quote:
Try to flash this file with z3x, and if it stell not working reinstall the usb drivers. | |
10-12-2013, 22:30 | #23 (permalink) | |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
but not sure if I try to flash Modem part and it will kill phone ? | |
10-12-2013, 22:30 | #24 (permalink) | |
just worried for flash the unlock file as it now appears KNOX in Download Mode... | |
10-12-2013, 22:36 | #25 (permalink) |
Member: 1563247 Status: Offline Thanks Meter: 57 | I know. The knox security is only about downgrade the bootloader (sboot.bin) or flash unofficial repacked img files (not signed by samsung) There is no problem to flash this file because it official samsung modem. i flashed this file also on phones with knox security. |
The Following User Says Thank You to avicohh For This Useful Post: |
10-12-2013, 22:44 | #26 (permalink) |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Thanks I had tried as your suggestion got Risk and it works and now finally got unlock codes with z3x now will try to put sim and check if it works or not Thank you for all who took time and help me in this thread. : UNLOCK Successful : Selected model: I9505 Selected port: COM39 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*27203513# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.16.0 Last edited by kariakala; 10-12-2013 at 22:52. |
10-12-2013, 23:01 | #28 (permalink) |
Member: 984046 Status: Offline Thanks Meter: 255 | ???? You can root knox enabled phone, by flashing it partially. It's allready considered a major security flaw of epic proportions, and most likely will be fixed very soon. But it's really strange that your phone is reverted state in a matter of de-branding. You are sure that you had customized phone with operator splash logo??? Maybe you had branded non knox "boot", which you could replace with no branding but other security featured firmware (knox enabled) ? It would be intresting to test, can you flash any other fw now? Br Haltec |
