samsung s4 i9505 3 uk unlock issue Mobile not show any option while dial *#7284# ( No variation ) can attach phone via usb drivers off adb drivers ok but not detected by z3x software ( no particular port ) Phone connected via usb ( phone shows only 2 options choose as Media Device ( MTP) Camera ( PTP) not show connected as USB Debugging !!!! ( even its usb debugging is already enabled. I tried to root as 4.2.2 os it is Original version it has AP : I9505XXUBMEA CP : I9505XXUBMEA CSC : I9505H3GBME3 downloadin file for flash the phone :I9505XXUDMH8_I9505OXXDMHA_BTU.zip is it worth to flash it with this file? Kindly help thanks. |
Unlock With Uart Cable c3300k Reads Codes OR Direct Unlock. WBR. Arsalan gsm2000. |
Selected port: COM39 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... error access denied Done with Samsung Tool v.14.4 Done with Samsung Tool v.14.4 |
Selected port: COM18 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.16.0 Done with Samsung Tool v.16.0 |
When you enter download mode, do you see KNOX Warranty.... ? Upper left corner. Very small. ? Haltec |
ODIN MODE - RED color PRODUCT NAME : I9505 CURRENT BINARYY: CUSTOM SYSTEM STATUS : CUSTOM CSB-CONFIG-LSB: 030 WRITE PROTECTION : ENABLE this text appears as in Download mode |
Ok. This one can be unlocked. Don't know for z3x, but for sure in Samsung ASC.... Which I can't say for Knox enabled phones. Look's that is going to be hassle with these. Samsung is somehow imagining that he's Blackberry. Br Haltec |
well Thanks for answer Trying it from many hours do I need to flash the phone? ( with written above firmware ) or its cause of new security of phone? can not be unlocked? |
About Simlock security Blang can provide way more info than anyone. I don't have exact thoughts about knox yet. We dont have an example of non-knox phone became one, after upgrade or flashing with Das. Apparently we (ASC's) will have same abilities/features as per older (S2,S3...) handsets. Allegedly there is option (Authorization file) which can disable knox and enable writing as per blank pcb, but, that info I'll not have till next week. Br Haltec |
where to select file in PDA ? or Modem? ( <OSM> End... <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> MD5 hash value is invalid <OSM> I9505 File for Unlock 4.2.2.tar.md5 is invalid. <OSM> End... will it make any issue?for unlock or kill phone? |
In pda. It will not make any problems. |
There is problem in the md5 verification. Download this file. https://mega.co.nz/#!WQtWAIIa!TUeXgl...Xrme2_ZO7j81u4 |
so can not try to flash with that errors |
