07-11-2009, 04:31 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 817022 Status: Offline Thanks Meter: 78 | Samsung S8300(tocco) unlock done in Z3x PROVIDER: 3 GADGET: Z3X box NOTE: Some samsung S8300 cannot be unlock directly, so in my case i re-flash the unit. here is my solution: Samsung S8300 with SW S8300_MNC1 re-flash to SW S8300_XFIC4 http://i465.photobucket.com/albums/r...eid/tocco1.jpg http://i465.photobucket.com/albums/r...d/tocco2-1.jpg http://i465.photobucket.com/albums/r...id/s8300-1.jpg .... after re-flash set phone to qualcomm mode. then unlock. hope it can help for reference....tnx |
The Following 6 Users Say Thank You to blood rAyne For This Useful Post: |
08-22-2011, 17:01 | #4 (permalink) |
Registered User Join Date: Mar 2011 Location: dubai
Member: 1545797 Status: Offline Sonork: 1596859 Thanks Meter: 91 | i am flash samsung s8300 wit (multiloader_5.62) MSM6275/MSM6280 Select Boot Change Select Full Download Select Master Rom. Click ‘BOOT’ and select the boot files and last slect flash file and last click donlowd |
08-26-2011, 15:46 | #5 (permalink) |
Freak Poster Join Date: May 2008 Location: united kingdom hull city
Member: 772904 Status: Offline Thanks Meter: 21 | unlock done after flash the phone Model: GT-S8300 CountryCode: ORA Factory SW: S8300BVIE1_IH1 UniqueNumber: 80450000811999 MemoryPhone: K5R2G1GACC(S8300)S IMEI: 35627603457000/0 Phone S/N: RVVZ440007 Build: M6281A-KLRZR-4.0.9640 Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM60) ----------------------------- Model: GT-S8300 CountryCode: ORA Factory SW: S8300BVIE1_IH1 UniqueNumber: 80450000811999 MemoryPhone: K5R2G1GACC(S8300)S IMEI: 35627603457000/0 Phone S/N: RVVZ440007 Build: M6281A-KLRZR-4.0.9640 Reading SysInfo... OK Calculating... OK Unlocking... OK (time - 00:00:00) Done with Samsung 3G tool ver 9.4 |
08-26-2011, 15:55 | #6 (permalink) |
Member: 772904 Status: Offline Thanks Meter: 21 | This link for firmware MultiLoader S8300JPIC5.rar - 4shared.com - online file sharing and storage - download password.GEM-FLASH Support. |
11-24-2011, 16:36 | #7 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | S8300 sucsess full unlock done z3x Count supported models - 253 Searching Samsung USB Modem... Detected (COM92) Model: S8300 SW: S8300MNIC5 IMEI: 359043022778366 Model: GT-S8300 Country Code: H3G Factory SW: S8300MNIC5 Unique Number: 60040000334905 Memory Phone: K5R2G1GACC(S8300)S Checking Phone On COM4... No Answer Done with Samsung Tool ver 11.2 Reading Phone Info... OK Reading SysInfo... Error Access Denied Done with Samsung Tool ver 11.2 Reading Phone Info... OK Reading SysInfo... Error Access Denied Done with Samsung Tool ver 11.2 Searching Samsung USB Modem... Not Found Checking Phone On COM4... No Answer Done with Samsung Tool ver 11.2 Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 11.2 Searching Samsung USB Modem... Not Found Checking Phone On COM4... No Answer Done with Samsung Tool ver 11.2 Searching Samsung USB Modem... Detected (COM92) Model: S8300 SW: S8300MNIC5 IMEI: 359043022778366 Model: GT-S8300 Country Code: H3G Factory SW: S8300MNIC5 Unique Number: 60040000334905 Memory Phone: K5R2G1GACC(S8300)S Checking Phone On COM4... No Answer Done with Samsung Tool ver 11.2 Searching Samsung USB Modem... Detected (COM92) Reading Phone Info... OK Model: S8300 SW: S8300MNIC5 IMEI: 359043022778366 Country Code: H3G Factory SW: S8300MNIC5 Unique Number: 60040000334905 Memory Phone: K5R2G1GACC(S8300)S Reading SysInfo... OK Searching server... OK Unlocking ... OK Done with Samsung Tool ver 11.2 |
04-17-2012, 15:20 | #8 (permalink) |
05-04-2016, 13:52 | #10 (permalink) |
Freak Poster Join Date: May 2015
Member: 2399952 Status: Offline Thanks Meter: 40 | UNLOCK INSTRUCTIONS: UART cable: 1. Phone must be powered on. 2. Connect the phone to UART cable. 3. Choose correct COM port in port settings. 4. Check security type ('Old Security' or 'New Security'). 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. USB cable with 'Old Security' option: 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If you got 'Calculating ... error' or 'Reading sysinfo ... access denied' errors, then you must check 'New security' option. USB cable with 'New Security' option: 1. Phone must be powered on. 2. Type *#726872# to switch phone to Samsung USB mode. 3. Connect USB cable, install drivers. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: GT-S8300 Selected port: COM10 Z3X BOX Serial Port Software version: 25.2 Searching Samsung modem... detected COM70 Reading phone info... Model: GT-S8300 Country code: ³²¾Æ°ø Cal date: 2009-06-12 Factory SW: S8300JCIE1 Unique number: 70500000698455 Memory phone: K5R2G1GACC(S8300)S Reading sysinfo... OK Searching server... OK Please wait, calculating codes... OK (time - 00:00:14) Freeze code: 38084807 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 12369874 For check lock status: *#7465625# Done with Samsung Tool PRO v.25.2 |
01-26-2018, 16:16 | #11 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | Flash S8300V just select S8300C and flash with file S8300BUIC6 uk vodapone file 100/100 tested me boot key numeber 9 & power button like you try to make power On Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. Check flashing options if needed (Auto reboot to flash mode, Boot update). 3. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 4. Connect phone to PC with USB cable, install drivers if needed. 5. Press 'Flash' button. Operation: Flash Selected model: GT-S8300C Version logiciel: 20.0 Recherche de l'interface Samsung USB flash... Détécté COM238 CPU type: MSM6275/MSM6280/MSM6290 (03) Flash page size: x0800 Flash page count: x0040 effacement AMSS... OK envoi AMSS... OK effacement RSRC1... OK envoi RSRC1... OK effacement RSRC2... OK envoi RSRC2... OK effacement FFS... OK Formatage FFS... OK envoi FFS... OK Flash réussie (Temps - 00:04:27) Réussie avec Samsung Tool v.20.0 |
i617 samsung 2pcs. unlock done in z3x... | alex_030385 | Z3X-Team Products | 31 | 04-27-2015 14:02 |
Samsung a867 unlock done by z3x [Report OK] | pradeep_kus | Z3X-Team Products | 5 | 11-29-2014 16:34 |
SAMSUNG C3110 unlock done with z3x. [Report OK] | baig65 | Z3X-Team Products | 0 | 11-01-2009 01:32 |
821sc samsung softbank unlock done in z3x...... | alex_030385 | Z3X-Team Products | 4 | 10-16-2009 05:38 |
709sc unlock done in z3x [Report OK] | .::AZEEM::. | Z3X-Team Products | 0 | 09-14-2009 10:45 |
