10-20-2018, 10:43 | #1 (permalink) |
Freak Poster Join Date: Oct 2009 Location: bangladesh
Member: 1142388 Status: Offline Sonork: 100.1617280 Thanks Meter: 85 | samsung sc-02h unlock error UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes via Server Selected model: SC-02H Selected port: COM434 SAMSUNG Mobile USB Serial Port Software version: 34.0 Checking Login and Password... OK Ballance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SC-02H Android version: 6.0.1 PDA version: SC02HOMU1APD6 CSC version: SC02HDCM1APD6 Phone version: SC02HOMU1APD6 Product code: SM-G935DZBADCM CSC country code: JP CSC sales code: DCM Phone SN: RF8J208LVFT IMEI: 356817076670592 HW version: REV0.4 RF cal date: 2017.02.04 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-04-02 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM331 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.34.0 plase help me |
