06-18-2013, 21:19 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | Samsung SGH-M919 Galaxy S4 T-Mobile Unlock Done Samsung SGH-M919 Galaxy S4 T-Mobile Unlock Done with Z3x Box Operation LOgs: ============= Code: Selected model: M919 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*30418379# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.14.7 Requirements : =========== 1-C3300K cable (UART Cable) 2-Z3x Box (Sure) 3- Samsung Tool (at least v14.4) Important Note : ============= You don't need ROOTING your device OR Enable USB DEBUGGING. Instructions: ========== 1- Press *#7284# and select "MODEM". 2- Press *#9090# and select " DM OVER UART". after that Phone will be Restarted ! 3- Choose Box Com port in Port filed. 4- Press Read Codes / Unlock. 5- Enjoy . |
The Following 11 Users Say Thank You to MR/TAMER_SiLver For This Useful Post: |
09-10-2013, 16:11 | #5 (permalink) | |
Junior Member Join Date: Feb 2010
Member: 1243533 Status: Offline Thanks Meter: 2 | Quote:
11-09-2013, 23:14 | #6 (permalink) |
Crazy Poster Join Date: Jan 2008
Member: 678472 Status: Offline Thanks Meter: 2 | i need you help !! for SGH-M919 emergency mode First dial *#0808# and select: DM - MODEM - ADB , its ok i select then *#9090# select: DM OVER UART[*] dont work i see in black all and no detect the phone Selected model: M919 Selected port: Selected port speed: 115200 Port not selected Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM7 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 Selected model: M919 Selected port: COM9 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.16.1 |
The Following User Says Thank You to framar80 For This Useful Post: |
12-12-2013, 19:31 | #8 (permalink) |
Insane Poster Join Date: Dec 2012
Member: 1847451 Status: Offline Thanks Meter: 45 | dial *#0808# select RNDIS+DM+MODEM click ok connect phone to USB cable. Select Samsung USB port and click Unlock. Tested on 50+ units. if still doesnt connect flash stock rom and try again. for USB connection *#9090# should be selected to DM/UM over HSIC |
The Following 2 Users Say Thank You to harpreetbraich For This Useful Post: |
12-14-2013, 11:46 | #9 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 37
Member: 585634 Status: Offline Thanks Meter: 45 | successfully unlock Samsung S4 M919 By Z3x Selected model: M919 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.1 |
01-20-2014, 15:00 | #10 (permalink) |
Junior Member Join Date: Jan 2010 Location: Kaithal Age: 31
Member: 1207907 Status: Offline Sonork: kamal5293 Thanks Meter: 0 | Selected model: M919 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 |
01-26-2014, 09:00 | #11 (permalink) | |
Registered User Join Date: Mar 2011 Location: dubai
Member: 1545797 Status: Offline Sonork: 1596859 Thanks Meter: 91 | Quote:
hvae u any sloution unlock 4.3 ver | |
02-04-2014, 12:42 | #12 (permalink) | |
Insane Poster Join Date: Feb 2010 Location: Bangladesh Age: 36
Member: 1224463 Status: Offline Sonork: Kafi_ctg Thanks Meter: 26 | Quote:
tnx a lot mate i just unlocked my s4..tnx a lot for shearing | |
02-10-2014, 13:29 | #13 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1640620 Status: Offline Thanks Meter: 1 | Selected model: M919 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.16.8 Selected model: M919 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Searching server... OK NET lock: #7465625*638*29393942# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 thanks bro |
02-19-2014, 01:50 | #14 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 339 | Quote:
i get this error Code: Selected model: M919 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17122 Reading security... error access denied Done with Samsung Tool v.16.9 Done with Samsung Tool v.16.9 | |
02-19-2014, 02:31 | #15 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
