12-26-2013, 00:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 183 | samsung sm-n900a big problem, was trying to unlock samsung sm-n900a in z3x knowing this model not supported so i was playing around with some model so try with model i9506 and press unlock but when reach to writing data to phone i unplug it because was kinda scared with writing data to phone so i unplug it. now big problem with phone only restart flash many times and same time come up with screen. PROCESS SYSTEM ISN'T RESPONDING. here is log Selected model: I9506 Selected port: COM221 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-N900A Android version: 4.3 Product code: SM-N900AZKEATT Phone version: N900AUCUBMI9 PDA version: N900AUCUBMI9 CSC version: N900AATTBMI9 IMEI: 358579051714658 Phone S/N: R31D913HDCF Checking phone at COM221 OK Backuping NVM... OK Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... Operation aborted Done with Samsung Tool v.16.2 please any one with idea what i may have damage in phone and if this can be repair in what ever means i will be greatful. |
12-26-2013, 02:21 | #2 (permalink) |
Freak Poster Join Date: Jan 2013 Location: socal
Member: 1866487 Status: Offline Thanks Meter: 113 | Next time just root and use free app from market called region lock away apk..works on att and tmobile n3 Sent from my SM-N900P using Xparent Skyblue Tapatalk 2 |
12-26-2013, 02:22 | #3 (permalink) |
Member: 1866487 Status: Offline Thanks Meter: 113 | Did u try Odin stock back onto device? Sent from my SM-N900P using Xparent Skyblue Tapatalk 2 |
The Following User Says Thank You to dam1inc For This Useful Post: |
12-27-2013, 06:56 | #8 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @lucky999 Hello z3x read and write efs block in process. you can fix only with dumping working phone efs block. make tar and write with odin or z3x but u may not able to fix imei if its damaged in case of z3x changed in security data. you can not read write efs partitions with z3x if phone is qualcomm it will only read nvitem. use any tool or commands to read it from working phone. make linux format tar and flash with odin 3.09 at pda and check. if flashing stuck at end attach me here efs file i fix it and then u can flash with odin. Regards, Chevli |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
12-30-2013, 06:28 | #9 (permalink) |
Member: 1643797 Status: Offline Thanks Meter: 183 | iam yet working on this phone not yet receive any working phone in hand for dumping efs but in mean time iam asking any one that have working phone and can dump efs and send to me i would be greatful.. SM-N900A NOTE 3 |
04-02-2014, 22:57 | #12 (permalink) | |
Junior Member Join Date: Feb 2008
Member: 711770 Status: Offline Thanks Meter: 2 | Quote:
sorry for my bad English | |
04-03-2014, 08:53 | #13 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
from 17.x or newer it can auto backup and make security area flashable tar with z3x or odin, if user used new version to make any operation like unlock,imei repair. check backup tar at "X:\Program Files\Z3X\Samsung\SamsungTool\Backup" | |
08-20-2014, 23:20 | #14 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lagos, Nigeria
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | i flashed my N900A 4.4.2 with 4.3 file. now it stucks on samsung. v tried many files ut wouldnt flash aklways write failed with all versions of odin. i need help to revive my phone pls. it was working in good condition just wanted to fix the hotspot |
