Old 03-09-2015, 18:15   #1 (permalink)
mediaextensions's Avatar
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 439
Samsung T199 Unlocked Successfully. [Done]
1. Turn phone on.
2. Enter *#782872# it will switch mode to Qualcomm and Confirm.
3. Connect phone to PC, install drivers if needed.
4. Select S8600 as your model.
5. Press Unlock to Direct Unlock then Enter 00000000.
6. When Successful your is UNLOCK.
Read Info
Searching Samsung modem... detected COM331
Reading phone info...
Model: SGH-T199
Phone version: Q6270B-KPEZL-4.2.31011ST 1 [Jan 13 2014 01:00:00]
IMEI: 35xxxxxxxxxxxxx0
Checking phone on COM329
Reading IMEI... OK
IMEI: 35xxxxxxxxxxxxxx0
Phone S/N: R21FA027QE
Build: Q6270B-KPEZL-4.2.31011ST
Done with Samsung Tool v.16.1
Unlocking
Selected model: S8600
Selected port: COM329 Samsung HS-USB Diagnostics 9002
Selected port speed: 115200
Software version: T199UVNBA
IMEI: 35xxxxxxxxxxxxxx /0
Product code: xxxxxxxxxxxxxx
Bypass MSL... OK
Unlocking... OK
Unlock done
Codes set to 00000000
Regards,
Mediaextensins.
Hit thanks if this helps you.
The Following 21 Users Say Thank You to mediaextensions For This Useful Post:
Old 03-18-2015, 06:11   #2 (permalink)
Member: 747354
mine has phone lock so i cannot access the keyboard any solution ?
Old 04-10-2015, 06:42   #3 (permalink)
master_t2's Avatar
Member: 321796
Thanks Meter: 65
Originally Posted by mediaextensions View Post
1. Turn phone on.
Read Info
Unlocking
Regards,
Mediaextensins.
Good job..............................................
The Following User Says Thank You to master_t2 For This Useful Post:
Old 04-10-2015, 18:34   #4 (permalink)
Member: 321632
Thanks Meter: 21
Well done sir
1. Turn phone on.
Read Info
Unlocking
Regards,
Mediaextensins.
Its working 100% huhuuuuhuuuuuuu
The Following 3 Users Say Thank You to mafolk For This Useful Post:
Old 04-22-2015, 10:13   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Searching Samsung modem... detected COM111
Model: SGH-T199
Country code: ¹Ì±¹/TMO
Cal date: 2014-02-27
Factory SW: NBA
Unique number: 31340000160989
Memory phone: MT29C2G24MAA(T199)
Bypass MSL... error
Done with Samsung Tool v.20.0
Old 04-24-2015, 10:03   #6 (permalink)
Member: 1783226
Sonork: 100.1619884
Thanks Meter: 7
Selected port: COM181 Qualcomm HS-USB NMEA 9002
Searching Samsung modem... detected COM182
IMEI: 35842***********
Bypass MSL... OK
Unlocking... OK
Unlock done
Done with Samsung Tool v.19.1
philipgsm GH
Old 04-27-2015, 08:37   #7 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Unlocked successfully in 19.1
Failed on 20.2
Old 04-28-2015, 10:35   #8 (permalink)
sandeephanda78's Avatar
Member: 330468
Sonork: 100.1587596
Thanks Meter: 121
unlock failed in 20.5 how we can unlock t199 now
Old 04-28-2015, 12:18   #9 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Use version 19.1 ... 100% Works
The Following 2 Users Say Thank You to Aamir_Zia For This Useful Post:
Old 05-15-2015, 10:27   #10 (permalink)
Member: 661195
Thanks Meter: 31
nice work...Big Thanks for you
Old 05-30-2015, 05:03   #11 (permalink)
Member: 1420901
Thanks Meter: 20
Selected port: COM207 Samsung HS-USB Diagnostics 9002
Searching Samsung modem... detected COM209
IMEI: 35842005655444 /5
Bypass MSL... OK
Unlocking... OK
Unlock done
1000% tested solution .
The Following User Says Thank You to NUR ISLAM For This Useful Post:
Old 06-03-2015, 16:08   #12 (permalink)
Member: 1038694
Sonork: 86
Thanks Meter: 30
u can successfully unlock t199 t moble with z3x v19.0 and 19.1
Old 06-03-2015, 16:35   #13 (permalink)
Member: 1038694
Sonork: 86
Thanks Meter: 30
here is clear true screen shot
[/IMG]
Old 06-09-2015, 16:48   #14 (permalink)
Crazy Poster
Member: 1180690
Thanks Meter: 6
thanks sir it working 100%
The Following User Says Thank You to tajani4u For This Useful Post:
Old 06-12-2015, 12:53   #15 (permalink)
samb-nd-ct's Avatar
Member: 289229
Sonork: samb-nd-ct
Thanks Meter: 195
Scegli modello S8600
Seleziona porta COM253 Qualcomm HS-USB Diagnostics 9002
Seleziona velocità porta 115200
Ricerca modem Samsung... Trovato COM251
Lettura info telefono...
Versione software: T199UVNBA
IMEI: 35842005422376 /1
Codice prodotto: xxxxxxxxxxxxxx
Bypass MSL... OK
Sblocco... OK
Sblocco eseguito
Codice impostato a 00000000
Eseguito con Samsung Tool v.17.4
Page generated in 0.20605 seconds with 8 queries
