03-09-2015, 18:15 | #1 (permalink) | ||
No Life Poster Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | Samsung T199 Unlocked Successfully. [Done] 2. Enter *#782872# it will switch mode to Qualcomm and Confirm. 3. Connect phone to PC, install drivers if needed. 4. Select S8600 as your model. 5. Press Unlock to Direct Unlock then Enter 00000000. 6. When Successful your is UNLOCK. Read Info Quote:
Regards, Mediaextensins. Hit thanks if this helps you. | ||
The Following 21 Users Say Thank You to mediaextensions For This Useful Post: |
04-10-2015, 06:42 | #3 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Mirpur-10.DHAKA
Member: 321796 Status: Offline Thanks Meter: 65 | Quote:
The Following User Says Thank You to master_t2 For This Useful Post: |
04-10-2015, 18:34 | #4 (permalink) | |
Insane Poster Join Date: Jul 2006 Location: Ghana, Akyem Oda
Member: 321632 Status: Offline Thanks Meter: 21 | Well done sir Quote:
The Following 3 Users Say Thank You to mafolk For This Useful Post: |
04-22-2015, 10:13 | #5 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Searching Samsung modem... detected COM111 Reading phone info... Model: SGH-T199 Country code: ¹Ì±¹/TMO Cal date: 2014-02-27 Factory SW: NBA Unique number: 31340000160989 Memory phone: MT29C2G24MAA(T199) Bypass MSL... error Done with Samsung Tool v.20.0 |
04-24-2015, 10:03 | #6 (permalink) |
Insane Poster Join Date: Jul 2012 Location: West Africa Ghana-Kumasi
Member: 1783226 Status: Offline Sonork: 100.1619884 Thanks Meter: 7 | Selected model: S8600 Selected port: COM181 Qualcomm HS-USB NMEA 9002 Selected port speed: 115200 Searching Samsung modem... detected COM182 Reading phone info... Software version: T199UVNBA IMEI: 35842*********** Product code: xxxxxxxxxxxxxx Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.19.1 philipgsm GH |
05-30-2015, 05:03 | #11 (permalink) |
Freak Poster Join Date: Oct 2010 Location: NARAYANGANJ BANGLADESH
Member: 1420901 Status: Offline Thanks Meter: 20 | Selected model: S8600 Selected port: COM207 Samsung HS-USB Diagnostics 9002 Selected port speed: 115200 Searching Samsung modem... detected COM209 Reading phone info... Software version: T199UVNBA IMEI: 35842005655444 /5 Product code: xxxxxxxxxxxxxx Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 1000% tested solution . |
The Following User Says Thank You to NUR ISLAM For This Useful Post: |
06-12-2015, 12:53 | #15 (permalink) |
No Life Poster Join Date: Jun 2006 Location: italia
Member: 289229 Status: Offline Sonork: samb-nd-ct Thanks Meter: 195 | Scegli modello S8600 Seleziona porta COM253 Qualcomm HS-USB Diagnostics 9002 Seleziona velocità porta 115200 Ricerca modem Samsung... Trovato COM251 Lettura info telefono... Versione software: T199UVNBA IMEI: 35842005422376 /1 Codice prodotto: xxxxxxxxxxxxxx Bypass MSL... OK Sblocco... OK Sblocco eseguito Codice impostato a 00000000 Eseguito con Samsung Tool v.17.4 |
