07-04-2017, 14:23 | #346 (permalink) |
Insane Poster Join Date: Jan 2017
Member: 2679051 Status: Offline Thanks Meter: 4 | Some services listed @ ebay are cheaper than this, at least make credits cheaper, $1 or $2 per unlock would be fair |
07-04-2017, 14:35 | #348 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2287393 Status: Offline Thanks Meter: 1 | Please z3x team repair this release failure sm-j510mn greetings and keep going Operation: Read Codes via Server Selected model: SM-J510MN Software version: 28.5 Checking Login and Password... Listo Balance: 45 crd. Waiting ADB device... Por favor, permite la depuración USB en el teléfono... Listo Leyendo información del teléfono ... Modelo: SM-J510MN Android version: 6.0.1 Código del Producto: SM-J510MZKNCHL Versión del telefono: J510MNUBU1APF2 PDA version: J510MNUBU1APF1 CSC version: J510MNUWA1APG1 Código de país CSC: Chile Código de Venta CSC: CHL HW version: MP 0.300 Phone SN: RV8HA0YZZQM Chip name: MSM8916 Módem: MSM8916 Security patch: 2016-06-01 RF cal date: 2016.10.21 IMEI: Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM5 detected Lectura de datos desde el teléfono ... Listo Calculando... error (2) Done with Samsung Tool PRO v.28.5 |
The Following User Says Thank You to lxcubyxll For This Useful Post: |
07-04-2017, 15:46 | #349 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | Easy Jtag - NOT available, activation possible Lg Tool - NOT available, activation possible Samsung Tool - activated 2014-05-18 Samsung Tool PRO - activated 2017-07-04 i have activated my z3x to pro because of this update lol... thank you z3x team |
07-04-2017, 15:48 | #350 (permalink) | |
Insane Poster Join Date: Nov 2011
Member: 1698693 Status: Offline Thanks Meter: 3 | Quote:
UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510MN Selected port: COM586 Z3X BOX Serial Port Software version: 28.5 Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J510MN Android version: 6.0.1 Product code: SM-J510MZWNCHL Phone version: J510MNUBU1APF2 PDA version: J510MNUBU1APF1 CSC version: J510MNUWA1APG1 CSC country code: Chile CSC sales code: CHL HW version: MP 0.300 Phone SN: RF8H90Q0BQL Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-06-01 RF cal date: 2016.09.08 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM83 detected Reading data from phone... OK Calculating... error (2) Done with Samsung Tool PRO v.28.5 Help pls. | |
07-04-2017, 15:58 | #351 (permalink) |
Member: 1698693 Status: Offline Thanks Meter: 3 | If you are a serious businessman, you has done a lot of money using this tool, including box and PRO activation cost. Why are you crying for pay developers new solutions? if you understand business, there are NO ONE that can unlock new qualcomm phones for 1 or 2 USD, in the past, you paid for past solutions, for new solutions, is logic to pay again. Sincerely, you will recover your invest and make a lot of money again. |
The Following User Says Thank You to alex369 For This Useful Post: |
07-04-2017, 16:33 | #352 (permalink) | |
Member: 2679051 Status: Offline Thanks Meter: 4 | Quote:
no one can unlock new qualcomm phone for $1 or $2, I know, thats why I say we should have some advantage in having paid for a box, or pro activation. Anyway, my message was not for you | |
07-04-2017, 16:36 | #353 (permalink) |
No Life Poster Join Date: May 2007
Member: 512970 Status: Offline Sonork: 100.1584185 Thanks Meter: 134 | Hello today the server z3x i think is good tested for s8 is done to nling u nedd to addedd aternative securty for fast sending codes by server br ..::mpogsm::.. |
07-04-2017, 16:38 | #354 (permalink) |
Member: 512970 Status: Offline Sonork: 100.1584185 Thanks Meter: 134 | Operation: Read Codes via Server Selected model: SM-G950W Selected port: COM5 SAMSUNG Mobile USB Serial Port Software version: 28.5 Checking Login and Password... OK Balance: 15 crd. Waiting ADB device... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZKAXAC Phone version: G950WVLU1AQD9 PDA version: G950WVLU1AQD9 CSC version: G950WOYA1AQD9 CSC country code: Canada CSC sales code: XAC HW version: REV1.0 Phone SN: R28J3XXXXXXX Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.03.21 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM8 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 27041424 NET lock: 63031471 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.5 |
07-04-2017, 19:34 | #359 (permalink) |
Junior Member Join Date: Jul 2007 Location: tunis
Member: 549911 Status: Offline Thanks Meter: 16 | Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZVAXAC Phone version: G950WVLU1AQC9 PDA version: G950WVLU1AQC9 CSC version: G950WOYA1AQC9 CSC country code: Canada CSC sales code: XAC HW version: REV1.0 Phone SN: R28J40WC6BY Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-03-01 RF cal date: 2017.04.10 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM82 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 35069186 NET lock: 84795736 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.5 Checking Login and Password... OK Balance: 45 crd. Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZKAXAC Phone version: G950WVLU1AQC9 PDA version: G950WVLU1AQC9 CSC version: G950WOYA1AQC9 CSC country code: Canada CSC sales code: XAC HW version: REV1.0 Phone SN: R28J41W975X Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-03-01 RF cal date: 2017.04.15 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM82 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 46051709 NET lock: 97193753 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.5 |
07-04-2017, 20:18 | #360 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | I have sc02h samsung japan like same cpu g930a Can i unlock with select that model?? Here is specifications Brand Samsung Model Galaxy S7 Edge SC-02H Also known as NTT DoCoMo Galaxy S7 edge SM-G935D, Samsung Hero 2 Country or region where it's sold Japan Release date May, 2016 Design / Type Bar Depth 7.7 millimeters (0.3 inches) Size (width x height) 72.6 x 150.9 millimeters (2.86 x 5.94 in) Weight 158 grams (5.53 ounces) Qwerty physical keyboard Not supported Antenna Internal antenna Water protection Waterproof (IPxx certified) Operating system (OS) Samsung Galaxy S7 Edge SC-02H Operating system Android 6.0.1 Marshmallow Firmware update Android 7.0 Nougat Hardware Samsung Galaxy S7 Edge SC-02H Architecture - Chipset 64bit - Qualcomm Snapdragon 820 MSM8996 (14nm) CPU processor Quad-Core, 2 processors: 2.15Ghz Dual-Core Kryo 1.6Ghz Dual-Core Kryo GPU graphical controller Qualcomm Adreno 530 |
