10-21-2020, 06:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | SM-A102U CRICKET BIT 6 not support [Solved] Phones locked by 'T-Mobile'(TMB, TMK), 'Verizon'(VZW), 'Sprint'(SPR) are not supported for unlocking! Unlocking using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock via server DIAG Oct 2019' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-A102U Software version: 41.3 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A102U Android version: 10 PDA version: A102USQU6BTE4 CSC version: A102UOYN6BTE4 Phone version: A102USQU6BTE4 Product code: SM2A102UZKZAIO CSC country code: USA CSC sales code: AIO Phone SN: RF8N628S14H IMEI: 356006111618044 HW version: REV1.0 RF cal date: 20200618 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2020-05-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM195 Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.3 BIT 6 not support need phone still locked need refund credits back on this USER CREDITS: zsc_nQF3QCK8 |
10-21-2020, 07:12 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 5,063 | Hello. Bit6 supported, just downgrade phone to A102USQS6ATC1 and repeat. If credits charged twice - knock me in pm with your login. |
The Following User Says Thank You to Z3X For This Useful Post: |
10-21-2020, 14:15 | #3 (permalink) |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | for info i will try to downgrade he will take a few hours. are you sure this model can downgrade because some model A10 cannot flash like that need token. |
10-21-2020, 14:19 | #4 (permalink) |
Member: 706257 Status: Online Thanks Meter: 5,063 | Token needed for flashing combination. This is stock firmware and same bootloader bit, but older security. Just flash it and repeat unlock |
10-21-2020, 15:27 | #5 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Dominican Republic
Member: 2342599 Status: Offline Thanks Meter: 98 | If you get some issue trying to download the patch's older firmware, here is A102USQS6ATC2: Link: https://androidfilehost.com/?fid=4349826312261772570 |
10-21-2020, 15:51 | #6 (permalink) | |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | unlock done he take credits twice Quote:
UNLOCK INSTRUCTIONS: Phones locked by 'T-Mobile'(TMB, TMK), 'Verizon'(VZW), 'Sprint'(SPR) are not supported for unlocking! Unlocking using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock via server DIAG Oct 2019' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-A102U Software version: 41.3 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A102U Android version: 9 PDA version: A102USQS6ATC1 CSC version: A102UOYN6ATC1 Phone version: A102USQS6ATC1 Product code: SM2A102UZKZAIO CSC country code: USA CSC sales code: AIO Phone SN: RF8N628S14H IMEI: 356006111618044 HW version: REV1.0 RF cal date: 20200618 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM195 Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.3 now sent 5 credits back | |
The Following User Says Thank You to ghacks For This Useful Post: |
10-21-2020, 15:57 | #7 (permalink) | |
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | for info Quote:
10-21-2020, 17:02 | #8 (permalink) |
Member: 706257 Status: Online Thanks Meter: 5,063 | Quote: |
08-04-2021, 22:45 | #14 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2558547 Status: Offline Thanks Meter: 1 | hi, i have problem to unlock : UNLOCK INSTRUCTIONS: Phones locked by 'T-Mobile'(TMB, TMK), 'Verizon'(VZW) are not supported for unlocking! Unlocking using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock via server DIAG Oct 2019' button or press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock AIO via Server Upload Nov 2020 Selected model: SM-A102U Software version: 43.7 Checking Login and Password... OK Balance: 8 crd. You have 8 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A102U Android version: 10 PDA version: A102USQSBBUF6 CSC version: A102UOYNBBUF6 Phone version: A102USQSBBUF6 Product code: SM2A102UZKZAIO CSC country code: USA CSC sales code: AIO Carrier ID: AIO Phone SN: RF8MC08XHZF IMEI: 357xxxxxxxxxx HW version: REV1.0 RF cal date: 20191205 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-06-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Reading IMEI... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM66 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Searching server... OK Waiting for server answer... error (1) Server error: Could not process security data, please try again Done with Samsung Tool PRO v.43.7 I already tried to flash the one they left here and it gives me an error, someone could help me to carry out the process |
08-05-2021, 08:35 | #15 (permalink) | |
