09-12-2020, 12:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | SM-A605F Flash error [Answered] FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A605F Software version: 41.2 File analysis... OK Total file size: 0x14101C22F (5136 Mb) Searching USB Flash interface... COM29 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.41.2 I want flash this version A605FJXS5CTF1_OJM5CTE1 phone show unknown picturs |
09-12-2020, 13:39 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
hello, have you tried to flash the 4 files the pit file? Or did you reinstall the phone drives or change your pc's usb cable or port? If it shows the same error it is a hardware problem replace emmc and not a software problem read these threads https://forum.gsmhosting.com/vbb/f45...error-2613190/ https://forum.gsmhosting.com/vbb/f45...error-2613190/ https://forum.gsmhosting.com/vbb/f45...wered-2622224/ | |
