04-15-2015, 09:25 | #16 (permalink) |
Freak Poster Join Date: Dec 2011
Member: 1702232 Status: Offline Thanks Meter: 38 | ----------------------------------------------------------------------------------- To connect GT-I9100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. Selected firmware file: I9100UHMS8_I9100IUSMS4_IUS_Android_ 4.1.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9100 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- To connect SM-G360H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G360H ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G360H Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G360H Firmware compiled date: Fri Dec 19 17:40:30 KST 2014 PDA version: G360HDDU0ANL3 CSC version: G360HOJV0ANL3 SW version: G360HDDU0ANL3 Phone IMEI: 357932062026391 Phone SN: R51G12043PE Android version: 4.4.4 (KTU84P) Connecting to phone's modem port, please wait... Found phone on COM106 Reading phone unlock codes. It can take some time, please wait... FREEZE unlock code: 96904093 NET LOCK unlock code: 15194802 Work time: 0:00:57 |
06-23-2017, 09:49 | #21 (permalink) |
Freak Poster Join Date: Sep 2006 Location: india, karnataka, bellary
Member: 358717 Status: Offline Sonork: 100.1648649 Thanks Meter: 44 | i root the set but still not woking sm-g360h ver 4.4.4 not decting driver but adb driver acgtivaate in other box any solution pls send me |
