04-23-2019, 08:00 | #4 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Here is log Code: REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Select device in ADB settings. 10. Fill values what you need to repair. 11. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Repair Selected model: SM-G7102 Selected port: COM159 SAMSUNG Mobile USB Serial Port Software version: 35.3 Waiting ADB device... OK Reading phone info... Model: SM-G7102 Android version: 4.4.2 PDA version: G7102XXSBQA3 CSC version: G7102OXEBOF1 Phone version: G7102DDUBNH1 Product code: SM-G7102ZKAINS CSC country code: Russia CSC sales code: SER Phone SN: IMEI: 351565072583245 HW version: RF cal date: 2014.02.22 Chip name: MSM8226 Modem board: MSM8226 Boot Warranty bit: 0 Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL OK Repairing WiFi Mac address... error Rebooting phone... OK Repair done Done with Samsung Tool PRO v.35.3 |
