07-28-2017, 21:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-g890a read codes for unlock codes done New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G890A Software version: 29.0 Searching Samsung modem... detected COM565 Reading phone info... OK Model: SM-G890A AP version: G890AUCS5CPI4 CSC version: G890AATT5CPI4 CP version: G890AUCU5API1 Product code: SM2G890AZAAATT Phone SN: R38G60JRX4F Unique number: 05157DF54A0B4C21 Reading IMEI... OK IMEI: 3593560XXXXXXSIGN: OK) Checking hash file... OK Reading data from phone... OK HWID: 88 9A 38 9F B4 05 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Please wait, calculating codes... OK (time - 00:00:13) Freeze code: 42057595 NET lock: 49150463 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
