07-31-2018, 21:17 | #31 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Quote:
Hallo. Please allow acces . I got the same issue with 3560000etc imei | |
07-31-2018, 21:46 | #32 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
CP_G920FXXU6ERD3_CP9525046_CL13115714_QB17869413_R EV02_user_low_ship.tar.zip EFS Backup: EFS_SM-G920F_G920FXXS3DPD5__R58G422B2EY_6-5-2016_17-21-0.tar NV_DATA: SM-G920F_2-1-2017_11-29-45__R58H70F60FK_nv_data.bin ROOT: Step 1: TWRP: twrp-3.2.2-0-zeroflte.img.tar Step 2: SuperSU: SR5-SuperSU-v2.82-SR5-20171001224502.zip Last edited by voltran2008; 07-31-2018 at 21:52. | |
The Following 6 Users Say Thank You to voltran2008 For This Useful Post: |
08-01-2018, 09:07 | #33 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
Thank's for files but same..No imei only SN .. Operation: Flash Selected model: SM-G920F Software version: 33.5 File analysis... OK Total file size: 0x02739310 (39 Mb) Searching USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Sending modem.bin... OK Flashing done (time - 00:00:05) Done with Samsung Tool PRO v.33.5 Operation: Write EFS Selected model: SM-G920F Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 PDA version: G920FXXU6ERF5 CSC version: G920FOXX6ERF2 Phone version: Product code: CSC country code: portugal CSC sales code: TPH Phone SN: R58G422B2EY IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Extracting EFS file... OK Converting Img to Ext4... OK Writing EFS to phone... OK Rebooting phone... OK Done with Samsung Tool PRO v.33.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 PDA version: G920FXXU6ERF5 CSC version: G920FOXX6ERF2 Phone version: Product code: CSC country code: portugal CSC sales code: TPH Phone SN: R58G422B2EY IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Writing NV Data... OK Recalculating MD5... OK Deleting backup... OK Write NV Data done Done with Samsung Tool PRO v.33.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 PDA version: G920FXXU6ERF5 CSC version: G920FOXX6ERF2 Phone version: Product code: CSC country code: portugal CSC sales code: TPH Phone SN: R58G422B2EY IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Can not detected modem type Done with Samsung Tool PRO v.33.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 PDA version: G920FXXU6ERF5 CSC version: G920FOXX6ERF2 Phone version: Product code: CSC country code: portugal CSC sales code: TPH Phone SN: R58G422B2EY IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 13) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.33.5 | |
The Following User Says Thank You to stefani For This Useful Post: |
10-06-2018, 17:08 | #35 (permalink) | |
Freak Poster Join Date: Oct 2015
Member: 2466934 Status: Offline Thanks Meter: 54 | Quote:
Thank you so much!! ur NV data worked like a charm, here is what i did 1: flashed giving u6 modem , on already flashed u6 firmware in the result baseband gone 2: rooted my phone with magisk instead supersu 3: reset efs from repair tab (baseband came back) 4: write giving efs (baseband unkown) 5: reset efs (baseband came back) 6: write given NV data (with a hash mismatch error, i just take my risk) 7: write imei ... it worked 8: install root explorer, and creat a new serial_no file (serial number came back) 9: patch certificate... done | |
The Following User Says Thank You to AM19x For This Useful Post: |
10-06-2018, 17:09 | #36 (permalink) | |
write nv data write imei patch certificate should be done 100% | |
02-05-2019, 08:18 | #37 (permalink) |
Freak Poster Join Date: Dec 2012 Location: chawinda
Member: 1861126 Status: Offline Sonork: [email protected] Thanks Meter: 32 | thnks its working first flash 6.0.1 repair 4 frimware thean cf auto root reset efs thn write nv data file write org imei thn z3x path certificate thean phone unlock don tested 10000000000000000 |
04-16-2019, 16:48 | #38 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | Quote:
i have done u6 with your files thanks bro | |
05-29-2019, 14:52 | #40 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Gambia
Member: 1440837 Status: Offline Sonork: 3535 Thanks Meter: 47 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Write CERT Selected model: SM-G920F Software version: 36.2 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 PDA version: G920FXXU6ERF5 CSC version: G920FEVR6ERF2 Phone version: G920FXXU6ERF6 Product code: CSC country code: UK CSC sales code: EVR Phone SN: RF8HB3Q357W IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 SIM State: READY Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 38 36 72 6E B4 05 00 00 00 00 00 00 00 00 00 00 Calculating... error Security damaged (hmac mismatch) Done with Samsung Tool PRO v.36.2 |
07-03-2020, 03:20 | #41 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | Quote:
07-03-2020, 03:20 | #42 (permalink) | |
07-03-2020, 03:22 | #43 (permalink) | |
07-04-2020, 09:17 | #44 (permalink) | |
