07-06-2018, 07:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | SM-G935f imei 00000 repair done by z3x [Done] i m stuck 3day bt aftr 3 day hrd wrk i got success when i try to repair bsbnd unkw problem always many user stuck in this problem like this http://forum.gsmhosting.com/vbb/f453...epair-2320878/ so lets start fst flash with this ver( for get batter result AP_G935FXXU2DRB6_CL12365438_QB16944063_REV00_user_ low_ship_meta.tar BL_G935FXXU2DRB6_CL12365438_QB16944063_REV00_user_ low_ship.tar CP_G935FXXU2DRB6_CL648265_QB8952208_SIGNED.tar CSC_WIN_G935FWIN2DRB3_CL12452365_QB16929838_REV00_ user_low_ship.tar note csc ver main n very very important (G935FWIN2DRB3) other wise u got always error here is logo REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 31.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 PDA version: G935FXXU2DRB6 CSC version: G935FWIN2DRB3 Phone version: G935FXXU2DRB6 Product code: CSC country code: ITALY CSC sales code: WIN Phone SN: IMEI: 3522150608xxxxx HW version: RF cal date: Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2018-02-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: FD F5 01 4B D0 92 BB E1 7C 7A 1C 1D BE 1D 06 55 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.31.4 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G935F Software version: 31.4 Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 PDA version: G935FXXU2DRB6 CSC version: G935FWIN2DRB3 Phone version: G935FXXU2DRB6 Product code: CSC country code: ITALY CSC sales code: WIN Phone SN: IMEI: 3522150608xxxxx HW version: RF cal date: Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2018-02-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.31.4 |
The Following 5 Users Say Thank You to aryanmobile1989 For This Useful Post: |
07-07-2018, 06:45 | #2 (permalink) |
Freak Poster Join Date: May 2010 Location: angeles city,pampanga Age: 45
Member: 1304373 Status: Offline Thanks Meter: 31 | can you share the certificate file you used and firmware for flashing.so that i can repair my unit on hand with 00000000000 imei.but good baseband.thanks in advanced sir. |
07-09-2018, 00:43 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Misiones
Member: 710759 Status: Offline Sonork: No Thanks Meter: 329 | need help for repair, i have 1 G935F when installa android 7.0 the phone only on in recovery mode, try differents firmware and not found, imei is null when try root in 7.0 recovery is not seandroid enforcing at moment not solution |
The Following User Says Thank You to Gabiunlock For This Useful Post: |
11-20-2020, 11:02 | #4 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Usbekistan Samarqand Bulung'ur
Member: 2154625 Status: Offline Thanks Meter: 76 | Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 8.0.0 PDA version: G935FXXU8ETI2 CSC version: G935FDBT8ETI2 Phone version: G935FXXU8ETI2 Product code: SM-G935FZDADBT CSC country code: Germany CSC sales code: DBT Phone SN: RF8H30RE20W IMEI: 35............ HW version: MP 0.801 RF cal date: 20160308 Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2020-09-01 Boot Warranty bit: 1 SIM State: READY Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... OK Reading data... OK HWID: 0A C8 D2 6D 18 8D 73 EF 0B 6B AC 07 8B 7C 1F EF Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.41.8 |
