04-09-2021, 08:40 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: 原產於ࡘ
Member: 820104 Status: Offline Sonork: 100.1606814 Thanks Meter: 114 | SM-G950FD FRP u11 [Answered] FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + 'Bixby' button + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G950F Software version: 41.8 File analysis... OK Total file size: 0x15B886845 (5560 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending up_param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending userdata.img.lz4... OK Sending modem.bin.lz4... OK Sending modem_debug.bin.lz4... OK Sending cache.img.lz4... OK Sending hidden.img.lz4... OK Flashing done (time - 00:04:02) Done with Samsung Tool PRO v.41.8 |
04-09-2021, 08:46 | #3 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Hello. Direct frp unlocking for this model currently not supported. IF you find combination for this bit - you can try combination method. |
The Following 2 Users Say Thank You to Z3X For This Useful Post: |
