04-15-2021, 09:30 | #1 (permalink) |
Insane Poster Join Date: Apr 2011 Location: ┌(* *)┐ Age: 43
Member: 1561637 Status: Offline Thanks Meter: 13 | Sm-g950u att [Answered] Exception: Access violation at address 00000000 in module 'SamsungToolPRO.exe'. Read of address 00000000 Done with Samsung Tool PRO v.42.10 UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950U Software version: 42.10 Checking Login and Password... OK Ballance: 37 crd. You have 37 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 9 PDA version: G950USQS7DTC1 CSC version: G950UOYN7DTC1 Phone version: G950USQS7DTC1 Product code: SM2G950UZSAATT CSC country code: USA CSC sales code: ATT Carrier ID: ATT Phone SN: correct IMEI: correct HW version: REV1.0 RF cal date: 2017.12.12 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Trying to enable diag port... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM5 Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM7 detected Reading data from phone... error (2) Exception: Access violation at address 00000000 in module 'SamsungToolPRO.exe'. Read of address 00000000 Done with Samsung Tool PRO v.42.10 ????? |
04-15-2021, 10:03 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 5,060 | Hello. Reflash phone with this firmware and then repeat operation, post result please. https://www.**************/samsung/g...U7DTF4/355679/ |
04-15-2021, 10:24 | #3 (permalink) | |
Member: 1561637 Status: Offline Thanks Meter: 13 | Quote:
04-17-2021, 09:32 | #5 (permalink) |
Member: 1561637 Status: Offline Thanks Meter: 13 | Hi, after flash Operation: Read Codes via Server Selected model: SM-G950U Software version: 42.10 Checking Login and Password... OK Ballance: 37 crd. You have 37 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 9 PDA version: G950USQU7DTF4 CSC version: G950UOYN7DTF4 Phone version: G950USQU7DTF4 Product code: SM2G950UZSAATT CSC country code: USA CSC sales code: ATT Carrier ID: ATT Phone SN: R38JC03M6PM IMEI: 357723082123098 HW version: REV1.0 RF cal date: 2017.12.12 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2020-06-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Trying to enable diag port... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM202 Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM16 detected Reading data from phone... OK Calculating... Exception: Data error Done with Samsung Tool PRO v.42.10 |
