10-17-2018, 16:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Ahemdabad
Member: 1988666 Status: Offline Thanks Meter: 31 | SM-G950u unlock error [Answered/Solved] I m getting error while unlocking samsung g950 u here is log:- UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Software version: 33.8 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQU5CRG3 CSC version: G950UOYN5CRG3 Phone version: G950USQU5CRG3 Product code: SM-G950UZSATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J546T4LA IMEI: 357754081550296 HW version: REV1.0 RF cal date: 2017.06.02 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-07-01 Boot Warranty bit: 0 Searching Samsung diag port... not found Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM31 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.8 Need Solution pls help me team thanks in advance..... |
10-17-2018, 17:01 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Flash eng modem from combination and retry http://www.mediafire.com/file/jgy0vr..._BIT5.tar/file |
10-17-2018, 17:56 | #3 (permalink) |
Member: 1988666 Status: Offline Thanks Meter: 31 | Thanks for your Fast reply my phone is now unlocked with your help and file..... with 4g network here is log.:- UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Software version: 33.8 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 8.0.0 PDA version: G950USQU5CRG3 CSC version: G950UOYN5CRG3 Phone version: G950USQU5CRF1 Product code: SM-G950UZSATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J546T4LA IMEI: 357754081550296 HW version: REV1.0 RF cal date: 2017.06.02 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-07-01 Boot Warranty bit: 0 Searching Samsung diag port... not found Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM31 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.8 |
The Following User Says Thank You to hardip4u For This Useful Post: |
01-03-2019, 15:25 | #5 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: SKN Caribbean Age: 41
Member: 919402 Status: Offline Sonork: ky Thanks Meter: 93 | Quote:
Regards | |
