07-28-2017, 13:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | SM-G955W Read Codes error??help me!!! Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955W Software version: 29.0 Checking Login and Password... OK Ballance: 45 crd. Waiting ADB device... OK Reading phone info... Model: SM-G955W Android version: 7.0 Product code: SM-G955WZKAFMC Phone version: G955WVLS1AQF7 PDA version: G955WVLS1AQF7 CSC version: G955WOYA1AQF7 CSC country code: Canada CSC sales code: FMC HW version: REV1.0 Phone SN: R28J41ZBWWX Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-06-01 RF cal date: 2017.04.18 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error () Done with Samsung Tool PRO v.29.0 |
07-28-2017, 13:19 | #2 (permalink) |
Member: 388862 Status: Offline Thanks Meter: 107 | ok UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955W Selected port: COM13 SAMSUNG Mobile USB Serial Port Software version: 29.0 Checking Login and Password... OK Ballance: 45 crd. Waiting ADB device... OK Reading phone info... Model: SM-G955W Android version: 7.0 Product code: SM-G955WZKAFMC Phone version: G955WVLS1AQF7 PDA version: G955WVLS1AQF7 CSC version: G955WOYA1AQF7 CSC country code: Canada CSC sales code: FMC HW version: REV1.0 Phone SN: R28J41ZBWWX Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-06-01 RF cal date: 2017.04.18 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 6407*** NET lock: 7063*** SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
07-28-2017, 13:23 | #3 (permalink) |
