06-24-2019, 17:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | Samsung S9 SM-G960F U5 Bit No READ CODES Code: UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Info Selected model: SM-G960F Software version: 36.8 Searching Samsung modem... detected COM5 Reading phone info... Model: SM-G960F AP version: G960FXXU5CSF2 CSC version: G960FOXM5CSF2 CP version: G960FXXU5CSF2 Product code: XEO Phone SN: RF8M52JZ4JN IMEI: 356204101626172 IMEI2: 356205101626179 Unique number: CE12182CCDDDED32017E Reading IMEI... OK IMEI: 356204101626172 (SIGN: UNKNOWN) IMEI 2: 356205101626179 (SIGN: UNKNOWN) Done with Samsung Tool PRO v.36.8 Code: UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G960F Software version: 36.8 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 9 PDA version: G960FXXU5CSF2 CSC version: G960FOXM5CSF2 Phone version: G960FXXU5CSF2 Product code: SM2G960FZKDXEO CSC country code: Poland CSC sales code: XEO Phone SN: RF8M52JZ4JN IMEI: 356204101626172 HW version: MP 0.900 RF cal date: 20190518 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2019-06-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.36.8 |
06-25-2019, 06:20 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | SM-G960f bit unlock not support [Answered] Checking Login and Password... could not connect to server Checking Login and Password... OK Ballance: 117 crd. You have 117 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 9 PDA version: G960FXXU5CSF2 CSC version: G960FOXM5CSF2 Phone version: G960FXXU5CSF2 Product code: SM-G960FZKDGLB CSC country code: PHILIPPINES CSC sales code: GLB Phone SN: R58K44L1 IMEI: 3571710990 HW version: MP 0.900 RF cal date: 20180428 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2019-06-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.36.8 |
06-25-2019, 08:03 | #3 (permalink) |
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | Code: UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Info Selected model: SM-G960F Software version: 36.8 Searching Samsung modem... detected COM5 Reading phone info... Model: SM-G960F AP version: G960FXXU5CSF2 CSC version: G960FOXM5CSF2 CP version: G960FXXU5CSF2 Product code: XEO Phone SN: RF8M52JZ4JN IMEI: 356204101626172 IMEI2: 356205101626179 Unique number: CE12182CCDDDED32017E Reading IMEI... OK IMEI: 356204101626172 (SIGN: UNKNOWN) IMEI 2: 356205101626179 (SIGN: UNKNOWN) Done with Samsung Tool PRO v.36.8 Code: UNLOCK INSTRUCTIONS: Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G960F Software version: 36.8 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 9 PDA version: G960FXXU5CSF2 CSC version: G960FOXM5CSF2 Phone version: G960FXXU5CSF2 Product code: SM2G960FZKDXEO CSC country code: Poland CSC sales code: XEO Phone SN: RF8M52JZ4JN IMEI: 356204101626172 HW version: MP 0.900 RF cal date: 20190518 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2019-06-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.36.8 Please add U5 bit support or upload modem U5 bit modem combi |
06-25-2019, 10:42 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
