11-26-2019, 18:42 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
In case you have already purchased the credits from the reseller and you have and usarname and password of z3x and you have tried to repair the net doing the patch cert, write in the post the log of z3x of the operation of patch cert as it is the result, if patch cert for j701f with binary 7 firmware was successful and the phone for emergency calls here on the z3x website you can check the firmware and modems tested for the cert patch for j701f with binary 7 firmware https://z3x-team.com/check-your-phone/ SAMSUNG TOOL PRO 38.6 AND SAMSUNG SM-J701F: Patch Certificate Patch Certificate using credits Tested firmwares: OTHER: J701FXXU1AQF1, J701FXXU1AQF5, J701FXXU1AQF8, J701FXXU1AQF9, J701FXXU1AQG1, J701FXXU1AQH3, J701FXXU1AQI1, J701FXXU2AQI2, J701FXXU2AQI4, J701FXXU2AQJ1, J701FXXU2AQK2, J701FXXU3AQL2, J701FXXU3ARA1, J701FXXU3ARA3, J701FXXU3ARA6, J701FXXU4ARB1, J701FXXU4ARB2, J701FXXU4ARC1, J701FXXU4ARD1, J701FXXU5ARF1, J701FXXU5ARG1, J701FXXU6ARH1, J701FXXU6BRH5, J701FXXU6BRH9, J701FXXU6BRI1, J701FXXU6BRI2, J701FXXU6BRJ1, J701FXXU6BRJ2, J701FXXU6BRK1, J701FXXU6BSC1, J701FXXU6BSC2, J701FXXU6CSF1, J701FXXU7CSG2, J701FXXU7CSG4, J701FXXU8CSK2, J701MTVJU6CSF1, J701MUBS6BSB4, J701MUBS6BSB6, J701MUBU3ARD1, J701MUBU6ASB1, J701MUBU6BSD1, J710FXXU6CSE1, J710KKKU1CRK5 Remember to download the latest version of z3x samsung pro tool 38.6 in case you have not done so in the case and you have used an old version of z3x to make cert patch to j701f with binary 7 firmware and after the patch was successful the phone it only makes emergency calls | |
