Old 11-26-2019, 11:46   #1 (permalink)
Member: 1839405
Thanks Meter: 41
SM-J701F emergency calls only
Hi i have J701f android9 u7.. aftter patch cert still emergency calls
Patch Certificate using credits ?
Old 11-26-2019, 18:42   #2 (permalink)
Member: 2613252
Thanks Meter: 1,837
hello, to make the cert patch through credits you have to buy through official reseller z3x a minimum of 30 credits that will not be deducted when you make the cert and repair imei patch and you will be generated username and password.
In case you have already purchased the credits from the reseller and you have and usarname and password of z3x and you have tried to repair the net doing the patch cert, write in the post the log of z3x of the operation of patch cert as it is the result, if patch cert for j701f with binary 7 firmware was successful and the phone for emergency calls here on the z3x website you can check the firmware and modems tested for the cert patch for j701f with binary 7 firmware
https://z3x-team.com/check-your-phone/
SAMSUNG TOOL PRO 38.6 AND SAMSUNG SM-J701F:
Patch Certificate
Tested firmwares:
OTHER: J701FXXU1AQF1, J701FXXU1AQF5, J701FXXU1AQF8, J701FXXU1AQF9, J701FXXU1AQG1, J701FXXU1AQH3, J701FXXU1AQI1, J701FXXU2AQI2, J701FXXU2AQI4, J701FXXU2AQJ1, J701FXXU2AQK2, J701FXXU3AQL2, J701FXXU3ARA1, J701FXXU3ARA3, J701FXXU3ARA6, J701FXXU4ARB1, J701FXXU4ARB2, J701FXXU4ARC1, J701FXXU4ARD1, J701FXXU5ARF1, J701FXXU5ARG1, J701FXXU6ARH1, J701FXXU6BRH5, J701FXXU6BRH9, J701FXXU6BRI1, J701FXXU6BRI2, J701FXXU6BRJ1, J701FXXU6BRJ2, J701FXXU6BRK1, J701FXXU6BSC1, J701FXXU6BSC2, J701FXXU6CSF1, J701FXXU7CSG2, J701FXXU7CSG4, J701FXXU8CSK2, J701MTVJU6CSF1, J701MUBS6BSB4, J701MUBS6BSB6, J701MUBU3ARD1, J701MUBU6ASB1, J701MUBU6BSD1, J710FXXU6CSE1, J710KKKU1CRK5
Remember to download the latest version of z3x samsung pro tool 38.6 in case you have not done so in the case and you have used an old version of z3x to make cert patch to j701f with binary 7 firmware and after the patch was successful the phone it only makes emergency calls
Page generated in 0.13129 seconds with 8 queries
