04-10-2015, 09:26 | #16 (permalink) | |
Freak Poster Join Date: Feb 2014 Location: INA
Member: 2130017 Status: Offline Thanks Meter: 43 | Quote:
04-12-2015, 05:49 | #17 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 158 | Selected model: SM-J100H Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-J100H Android version: 4.4.4 Product code: SM-J100HZBDKSA Phone version: J100HXXU0AOB1 PDA version: J100HXXU0AOB4 CSC version: J100HOJV0AOB1 IMEI: 3584xxxxxxx Phone S/N: RV1xxxRN Checking Super user right... true Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.19.0 Done with Samsung Tool v.19.0 |
05-19-2015, 08:22 | #20 (permalink) |
Junior Member Join Date: May 2015
Member: 2395553 Status: Offline Sonork: [email protected] Thanks Meter: 0 | hi i am having problem to root j100h and could not find root file too .....any one can help me |
05-19-2015, 08:45 | #21 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Quote:
Root with Download iRoot v2.0.8 and finally proceed with unlock. Regards | |
09-20-2015, 12:22 | #23 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2461652 Status: Offline Thanks Meter: 0 | hi guys, phones are bricking because might be the root file means the kernal file is different. as my firmware version is J100HDDU0AO1. but the file above is different. can anyone please make a root file for my firmware version. |
10-06-2015, 18:06 | #24 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1454749 Status: Offline Thanks Meter: 0 | samsung SM-J100H NETWORK LOCK Operation: Unlock Selected model: SM-J100H Software version: 20.5 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J100H Android version: 4.4.4 Product code: SM-J100HZWDKSA Phone version: J100HXXU0AOF2 PDA version: J100HXXU0AOF2 CSC version: J100HOJV0AOF2 CSC country code: KSA CSC sales code: KSA HW version: MP 0.201 Phone S/N: R21G52Y0E5J Modem board: sc7727s RF cal date: 20150527 IMEI: 357947065728983 Checking Super user right... false This model not supported for auto root Done with Samsung Tool v.20.5 root file for my firmware version. PLEASE GIDE ME |
10-31-2015, 16:57 | #26 (permalink) |
Freak Poster Join Date: Jun 2007 Location: United Kingdom
Member: 533083 Status: Offline Thanks Meter: 76 | J100 Unlock Without Root... Just click on REad code.. Enable usb debug... Install Drivers... And select model...Click on read code..Voila... UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J100H Software version: 23.2 Searching Samsung modem... detected COM113 Reading phone info... OK Model: SM-J100H Version: J100HXCU0AOC3/J100HOPT0AOD1/J100HXCU0AOC3/J100HXCU0AOC3 Product code: SM-J100HZKAOPT Phone S/N: R51G81GJT5W Imei: 3528300760xxxxx Unique number: C01CF61B5C372 Reading codes... OK Please wait, calculating codes... OK (time - 00:03:10) Freeze code: 64796464 NET lock: 58635261 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.2 |
01-07-2016, 17:35 | #28 (permalink) |
Crazy Poster Join Date: Nov 2012 Location: GSM KINGDOM
Member: 1833305 Status: Offline Thanks Meter: 12 | SAMSUNG J100H SUCESSFULLY UNLOCK BY READ CODE WITHOUT ROOT UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J100H Software version: 23.9 Searching Samsung modem... detected COM133 Reading phone info... OK Model: SM-J100H Version: J100HXCU0AOD1/J100HSWR0AOD1/J100HXCU0AOD1/J100HXCU0AOD1 Product code: SM2J100HZWASWR Phone S/N: RV1G909SRFZ Imei: 3530100xxxxxxxx Unique number: C012BABC0BE82 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:23) Freeze code: 37904692 NET lock: 35920252 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.9 * |
