06-03-2017, 04:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | sm-j327p latest build unlock done QB6 Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J327P Software version: 28.2 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU1AQB6 PDA version: J327PVPU1AQB6 CSC version: J327PSPT1AQB6 CSC country code: USA CSC sales code: SPR HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2017-02-01 RF cal date: 2017.03.10 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
07-03-2017, 10:55 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J327P Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU1AQB6 PDA version: J327PVPU1AQB6 CSC version: J327PSPT1AQB6 CSC country code: USA CSC sales code: SPR HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2017-02-01 RF cal date: 2016.12.28 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
