02-13-2018, 23:29 | #47 (permalink) | |
Freak Poster Join Date: Feb 2016 Location: Cayman Islands
Member: 2529251 Status: Offline Thanks Meter: 275 | Exynos Quote:
02-14-2018, 06:02 | #48 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | for the info Quote:
02-14-2018, 14:47 | #49 (permalink) | |
Freak Poster Join Date: Oct 2015 Location: USA
Member: 2474830 Status: Offline Thanks Meter: 48 | Quote:
I hope the other guy that have post the news share the proccess using octo, cos that like that its a useless post. Waiting for some reply. | |
02-14-2018, 22:37 | #50 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Well the idea was that once the Sprint J327P is converted to Exynos J327F then the regular Exynos unlock should work. After the conversion did you guys select the J327"F" model to try to unlock? Maybe even try rooting it via eng-boot or CFRoot. This link doesn't seem to open. http://forum.gsmhosting.com/vbb/f684...d-1st-2344055/ | |
The Following User Says Thank You to BillA For This Useful Post: |
02-22-2018, 21:22 | #51 (permalink) |
Junior Member Join Date: Nov 2017 Location: USA
Member: 2779485 Status: Offline Thanks Meter: 1 | please can you help me to downgrade the j327pvpu3aqj3 to j327pvpu1aqf4 I need to do that, it keep fail on bootloader |
The Following User Says Thank You to workhere For This Useful Post: |
03-19-2018, 07:19 | #53 (permalink) | |
Freak Poster Join Date: May 2009 Location: philippines Age: 36
Member: 1024596 Status: Offline Thanks Meter: 53 | Quote:
Phone version: J327PVPU3AQL3 PDA version: J327PVPU3AQL3 CSC version: J327PSPT3AQL3 CSC country code: USA CSC sales code: SPR HW version: J327P.03 Done with Samsung Tool PRO v.30.5 | |
03-22-2018, 16:03 | #54 (permalink) | |
Looks like there are two solutions out at the moment. The first one is offline and it's permanent (expensive!): Samsung J327P QJ3 Rev 3 UNLOCK PERMANENT SOLUTION PAID Download | Size: 50 MB | Date: 2018-03-21 14:50:37 | Price: 295.00 USD And the second one appears to be server based but it relocks when reflashed with stock, but supposedly survives a factory reset: Loading ADB module.........OK Starting ADB module...OK Searching for SAMSUNG ADB device...OK Checking device authorization...OK Reading ADB device information... ADB Serial Number : E4DCF2E9 Model Name : SM-J327P Searching for SAMSUNG Mobile USB Modem...OK SAMSUNG USB Modem detected on [COM40] Looking for DEVICE...OK Reading USB MODEM information...OK MODEL : SM-J327P VER : J327PVPU3AQL3/J327PSPT3AQL3/J327PVPU3AQL3/J327PVPU3AQL3 IMEI : 3569640847443xx S/N : 0000000000 U/N : CQ300E4DCF2Exxx Connecting to USB Modem...[COM40]...OK Restarting to DL Mode...OK [COM17] Setting up module...OK Initializing memory...OK Transmitting data...OK Rebooting phone to NORMAL mode...OK Loading ADB module..OK Starting ADB module...OK Searching for SAMSUNG ADB device...OK Checking device authorization...OK Activating USB Diagnostic Port...OK Searching for SAMSUNG Diagnostic Port...[COM41]...OK Release : Dec 18 201709:53:53Sep 01 2017J327P.038937 Initialize result : OK Authorizing EFS access...[PW1:OK]...[SPC:N/A]...OK(1) Reading NV network data...OK Reading NV Elements...OK Reading NV config...OK Reading NV registry...OK Sending data to SERVER...OK Waiting for SERVER response...OK Preparing for SEC write...[0x41]...OK Writing SEC data to EFS...[FS1:OK]...OK Saving data to EFS...[0x17]...OK Connecting to USB Modem...[COM42]...OK Restarting to DL Mode...OK [COM17] Setting up module...OK Initializing memory...OK Transmitting data...OK Rebooting phone to NORMAL mode...OK Operation successful. | |
03-23-2018, 00:53 | #55 (permalink) |
Insane Poster Join Date: Jun 2014
Member: 2211497 Status: Offline Thanks Meter: 37 | What's New: - Added full support for J327P QL3 (Latest firmware) - Fixed WIFI problem after J327P QL3 Unlock - WARRANTY VOID / KNOX WILL REMAIN 0 After J327P BIT3 Unlock !!! NOTICE : There are some other solutions on the market that they claim phone will NOT relock after wipe .. BECAREFULL !! They are lying !!! They damage the DM-Path in phone and RESET FACTORY Will NOT WORK at all! You will see this screen when try to do reset factory : |
03-23-2018, 00:55 | #56 (permalink) | |
Member: 2211497 Status: Offline Thanks Meter: 37 | Quote:
even if u pay with server it will still re-lock after a reset from recovery oh if u do the ##rnt# | |
03-23-2018, 01:03 | #57 (permalink) |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | This is combinefile - I've spoken with them and they confirmed that this is temporary like the others, not permanent. |
The Following User Says Thank You to gsm_service4u For This Useful Post: |
03-23-2018, 01:06 | #58 (permalink) | |
all solution are the same Last edited by tonasoledad; 03-23-2018 at 01:09. Reason: inf | |
03-24-2018, 15:03 | #60 (permalink) |
Junior Member Join Date: Jan 2009 Location: DUBAI
Member: 956482 Status: Offline Sonork: [email protected] Thanks Meter: 1 | pls help sir i unlock j327p |
The Following User Says Thank You to prasadpv For This Useful Post: |
