03-29-2019, 10:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | SM-J530f dm varity faild solved by full flashing FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J530F Software version: 35.2 File analysis... OK Total file size: 0xFE3ED41C (4067 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending userdata.img.lz4... OK Sending modem.bin.lz4... OK Sending cache.img.lz4... OK Sending hidden.img.lz4... OK Flashing done (time - 00:04:07) Done with Samsung Tool PRO v.35.2 |
